Need 4 lugs rims to replace stolen rims/tires - Sport AT
Old Jul 23, 2008 | 12:25 PM
mahout's Avatar
Originally Posted by mbfavreau
Thats why I got the 15' and with 40mm offset. From tire rack, they guarantee a fit so you can return them no questions asked if they rub or don't work.
what size tire? If you go with 205/50x15's you will likely get rubbing because the tire is not only wider but taller. Can't believe TR didn't put conditions on especially if you got them to mount and balance the tires on the rims.
good luck.
Old Jul 23, 2008 | 12:34 PM
mbfavreau's Avatar
The tires are 195/55/15, the rim is 38mm offset. I went as conservative as I could to guard against any rubbing. There's no problem with these specs, are there?
I also reminded them about the sensors... I'm crossing my fingers.
MBF
fittingaround
Sep 15, 2012 03:51 AM
EMC2
Jul 23, 2012 01:34 AM
Fit4Spl
Mar 22, 2012 06:19 PM
kdean101
Feb 14, 2009 09:53 AM
unphit
Feb 20, 2008 10:45 PM
