Moving to 15" Wheels for Snow Tires for '09 Fit Sport?
Old Nov 30, 2011 | 06:34 PM
littleblackcar's Avatar
Originally Posted by micven55
No, a new tire size will not affect the odometer if properly selected. See this link at miata.net (my other car).
Tire size calculator
As long as the outside diameter is the same you can use any size wheel that fits over the brake calipers (for the Fit the smallest size wheel is a 14", anything smaller will interfere with the caliper). Play around with it, you can use 195/40/18 tires (if you can find them) if you want to go with bigger rims. Won't affect the odometer or speedometer one bit.
As far as mpg is concerned if you go to snows you'll always get lower mileage. Not much, I'm seeing 1mpg less.
It seems like going from 175/65/15 to 185/60/15 is the least change. From 24" to 23.7". 60mph to 59.5mph. Could there be something better, or exact?
BigSpark
Feb 24, 2021 12:23 PM
rocketcat
Nov 3, 2018 06:48 AM
SilverEX15
Sep 16, 2014 02:40 PM
mtgirl
Sep 28, 2013 11:41 PM
dc9mm
Jan 14, 2009 12:16 PM
