Dashcam fusebox connecting question
I just bought a Rexing V1P Gen3 front and rear dashcam. I have a 2019 EX and I was wondering if it was possible or smart to connect the camera directly to the fuse box to have the camera always on.
Any advice would be greatly appreciated. I'm pretty handy with repairs but I am unfamiliar with electrical stuff. |
Wouldn't that drain the battery after a while if your intention that it would always be on?
He's right. Dashcams have a high current draw. As long as you're running your car every day which will recharge the car battery you might be OK but if you let your car sit for a day or two because you're not using it then you might not be able to turn it over. If your dashcam has a motion detector so that it's only on when movement is detected then that would be much better than just always on.
Get a dashcam battery pack. Made a huge difference for me. https://www.blackboxmycar.ca/collections/battery-packs
That is my fear, especially since the fit battery is smaller...
Originally Posted by Action Jackson
(Post 1432002)
(Post 1432002)
Originally Posted by 2Rismo2
(Post 1432053)
I had actually looked at using a jump starter pack I had. Have that charging while driving, then plug in the dash cam into one of its USB ports. I forget how man MA it has but should run for a while at least.
Originally Posted by DisappointTheFuture
(Post 1432047)
