Extended Cargo liner for seats down?
I couldn't find a Husky or Weather Tech cover that extended to the back of the rear seats when they are down. Looking to store lots of outdoors gear in the back for road trips and need some suggestions for protecting this area. I suppose I could just use a tarp if nothing else. Thanks everyone!
Home Depot sells a cushioned floor mat that is just about the same size as the area of the folded down back seats. I use this when I load up the back of my car with trail work tools and so far, it's worked great. It's some kind of rubber or vinyl product so easy to clean. I just roll it up to store when it's not needed. I think it was about $30.
Did you mind sending me a picture of it. I appreciate the help!
1 Attachment(s)
Measures 35"x47". Can be cut to fit.
I bought a thin, carpet one side, rubber other side, mat from the local hardware box store and cut it to fit. I also cut it in two pieces so the liner can be used with the rear seats up. Leave it a bit long against the backs of the front seats so you can protect your seat backs from muddy tires etc. If my stuff is dirty I put the rubber side up for easy cleaning. Usually I leave the carpet side up to prevent stuff from sliding around.
http://m.homedepot.com/p/TrafficMASTER-Black-36-in-x-48-in-Foam-Commercial-Door-Mat-60-169-0900-30000400/206498907 |
