Brake shim loose
Old Jun 23, 2022 | 04:33 AM
Pep's Avatar
Pep
Brake shim loose
So I changed my calipers rotors and pads. The calipers came with clips as well as the pads. I used the clips from the caliper. I put a little grease on the pads. A few days later I noticed a scratch on the new rotors. The shim came loose and fell onto the rotor. Not sure if the grease seeped in and separated or because I did not use the clips that came with the pads. Did not think anything of it but they were easier to install. Also th pads only had two folds on the top and only one on the bottom. Normally there are three on top and two on the bottom. Cheap pads or Were those clips specific for the pads. If they fall off again I will just remove the shims. Thanks
Old Jun 26, 2022 | 10:51 AM
GGG's Avatar
GGG
bummer. How was the shim attached? grease could definitely attack an adhesive.
mitcho85
Oct 12, 2018 06:32 PM
gkitf16
Jun 14, 2017 11:54 PM
silentnoise713
Jul 14, 2014 02:00 PM
The Critic
Feb 28, 2011 03:26 PM
mikejet
Sep 12, 2009 11:12 PM
