Armorall Headlight Cleaner F Y I
Old Feb 5, 2023 | 10:50 PM
spotnz's Avatar
hi,
This some F Y I stuff, that might save you time & $$ .
I've just tried to clean my headlights, with less than the desired results. The photos show them after using the alleged good product.
Even reading the Instructions first & doing my best to follow them. Did not help.
This possibly seems to be because the supplied sandpaper pieces are unable to stick to the supplied sponge pads. Because as soon as the pads get loaded with lubricant, the sandpaper falls off .
Googles search headlight restoration sandpaper grit results recommended from 800 to 2000 grits. Whilst Armorall grits were not accurately labeled. The finest was possibly 8,000. With the roughest possibly 2,000.
After being less than impressed with the first ( left ) headlight. I soaked the right in WD40 for 15 minutes, before trying googles sandpaper choices, over a small non-critical portion of the lens. Which also proved to give less than the desired results. So I reverted to trying to follow The Instructions. With the result shown.
I'm going to buy some sponge backed velcro pads & appropriate sandpaper pieces to use, next time.
david
Old Feb 6, 2023 | 06:37 AM
Rick_a's Avatar
I've had good luck with Flitz polish.
Old Mar 4, 2023 | 07:24 PM
borner's Avatar
Project farm did a test and found a Sylvania kit worked the best..
https://youtu.be/iDB5U4QUdD0
I was going to try it on my GD. I also read about just getting some 2k clear coat and sand paper, which can last much longer.
Old Mar 6, 2023 | 03:24 AM
Jeff Scott's Avatar
Before we traded our '09 Fit Sport for the '19 Fit EX we now have we tried using baking powder (BP) to attempt to clean/clear the lenses on its headlights. Using various ratios of BP/ water we did manage to get the lenses fairly clear but they weren't perfect, just better.
Old Mar 6, 2023 | 07:28 AM
Chitown Fit's Avatar
Cleaning Headlight Lens.
What I started doing is cleaning the headlight lens every month or two to keep it from clouding up. Seems to work.
Alco RS-1
Oct 10, 2021 08:37 AM
GD3 GeGe~
May 29, 2020 02:17 PM
Stacey444
Jul 30, 2019 10:50 PM
Zero2Hero
May 28, 2018 04:55 PM
Crawly
Apr 14, 2014 12:58 AM
