Question about non OEM parts
Old Apr 20, 2023 | 11:15 PM
phrancofile75's Avatar
hi - newbie here but proud original owner of a 2012 Fit with almost 170,000 miles!! Still running strong but needs a little TLC - specifically new front compliance bushings and Sway Bar links - already a little pissed that I have to replace the entire lower control arm/ball joint assembly as they don't sell separate compliance bushings, unless anyone knows where I can get just new bushings - but if I have to replace the whole thing, I'm looking to go with non-OEM parts because going OEM is SPENSIVE!! So, asking my fellow fit owners if they've used any other makers of parts and if they are any good, what are the best non-OEM makers - I've heard good things about MOOG if anyone has had any experience with their parts - and of course if anyone knows where I could just get the compliance bushings if possible - any info would be greatly appreciated and thanks in advance!
Old Apr 21, 2023 | 09:30 AM
Frenzal's Avatar
For the links, don't go with OE! They are cheap plastic...
I've had great experience with MOOG: they are beefier and you can grease them yearly. They are also cheap on Rock Auto!
Old Apr 21, 2023 | 12:03 PM
jonshonda's Avatar
imho OEM control arms, moog links. That is across the board for all manufacturers.
Old Apr 22, 2023 | 10:35 PM
2015LXFIT's Avatar
Look underneath the control arm section titled control arm bushings on rock auto for your compliance bushings... MOOG, Lemforder and sometimes ultra power (often repackaged wholesale parts) are my go tos.
Old Apr 25, 2023 | 11:21 PM
chedd7's Avatar
MOOG has worked great for me with Fit and other cars, Rockauto FTW
Old May 8, 2023 | 10:20 PM
MTLian's Avatar
I got a LCA from Canadian Tire, the worst parts store in Canada for my GD3 fit and it’s been pretty solid! Lifetime warranty too. It’s not the biggest job in the world to do if you have access to a lift and a ball joint separator. The moog part was way more expensive and with shipping, nearly = in price to OEM. I changed the sway bar links for OEM. They do have plastic bushings but they have held up fine for at least 4-5 years now on my neighbourhood streets with insigne potholes.
the way I look at it is that my car is 15 years old…OEM parts will probably last 7-10 years and aftermarket about 4-7 years at best. One thing I will never get aftermarket are engine mounts. Those are trash, will transmit more vibes and probably end up cracking early, and damaging other parts of the engine. Plus some are a real beeotch to change.
Old Jun 28, 2023 | 04:08 PM
mkchiu's Avatar
I've heard of MOOG having bad QC / tolerance, so would check TRW or OEM.
Old Jun 30, 2023 | 01:22 AM
dosbirn's Avatar
I had to have my front end parts on my 2012 Sport replaced June 8 at 198,650 miles. Hit a bad spot in the road and it knocked pieces off one of the dry-rotted bushings.
We used our local tire shop. Cost was $82.50 each for 2 "Import Direct Chassis Stabilizer Bar Link Kits" plus $73.50 labor, total cost = $238.50. Considering the age & miles on my car, we were happy with that. They said we really should've had this done when we had the struts replaced a year ago.
Old Jun 30, 2023 | 11:30 PM
MTLian's Avatar
prices have surely gone up but I replaced my sway bar links with OEM about 5 years ago and they were about 50$ each.
Old Jul 1, 2023 | 09:05 AM
dosbirn's Avatar
Right! Everything has at LEAST doubled. Ridiculous!
Old Jul 2, 2023 | 01:07 PM
Frenzal's Avatar
Next time, check on Rock Auto for MOOG end links. They are better quality than OE and are quite cheap!
Old Jul 2, 2023 | 02:43 PM
dosbirn's Avatar
I’m sure OE wasn’t used on my car but I wouldn’t install them myself. Great suggestion for anyone who does their own work. 👍🏻
Old Jul 11, 2023 | 06:50 PM
Jimmy101's Avatar
MOOG hasn't been good for quite some time now, they resell chinese junk in moog boxes.
Just get original parts. Makes no sense to have a high reliability car and install low reliability parts!!
Old Jul 12, 2023 | 06:25 AM
Frenzal's Avatar
No problem with MOOG endlinks from Rock Auto.
They are way better then OE, for less than half the price.
phoenity
Jan 23, 2019 04:14 PM
Fit09Chicago
May 21, 2017 11:42 PM
dewthedew
Apr 30, 2013 08:50 AM
sphagnum
Nov 16, 2011 09:03 AM
heweijun8
Canada Fit Forums & Clubs
Apr 19, 2009 08:14 PM
