Can't pull 30 amp square fuse
Is there a trick to pulling the little square 30 amp fuse for the blower? (#57). I tried using the little Honda fuse puller but the jaws are not big enough to fit. I tried using a needle nose and even a very small needle nose but I only succeeded in breaking off the clear plastic cover which went flying someplace....
Anybody know how I can release this 30 amp square fuse from the fuse block? I need this rather desperately. Thanks https://cimg5.ibsrv.net/gimg/www.fit...e3e9f39cc1.jpg 30 amp square fuse anks. |
I use a pick or two, sometimes a finger. Just wiggle
Thank you 2015LXFIT! I'll give that a try.
Jeff |
| All times are GMT -4. The time now is 07:37 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
