Fit 5spd manual - agressive drivers report
Old Jan 26, 2008 | 10:48 AM
coupdetat's Avatar
I'll echo all the other opinions here, the Fit isn't fast but its a LOT of fun through the curves. I put a RSB and Tanabe springs in my car and it handles like a dream. I'm always so excited to work it out on a twisty road and the shifter is fantastic--definitely better than the Mini Cooper and Neon SRT-4 I test drove but worse than the Miata. I would say it's at least as fun as a base Mini Cooper with a lot more utility, and cheaper and more reliable too.
Old Jan 26, 2008 | 10:59 AM
Raaaaaaaaaay.'s Avatar
Posts in the NUUDE
Well, I dont drive my car light. Im at 20,000miles and my clutch is doing great.
So far at least. I dont do burnouts and stuff, I have and the Fit holds a nice little burnout for a little motor.
Old Jan 26, 2008 | 11:45 AM
CorrodesTheFilm's Avatar
Yeah, although the Fit isn't fast by any means, it is fun to drive aggressively. Remember, it's always more fun to drive a slow car fast than it is to drive a fast car slow.
You have to remember with only 109 horses on tap, you're not going to beat on the clutch too bad, unless you do things like hold the car in place on hills with the clutch. But that's just a bad idea in any car.
As far as the engine goes: it's a 1.5L Honda motor, I wouldn't worry at all about running it right up to the limiter every day.
Old Jan 28, 2008 | 12:36 AM
kz098123's Avatar
My clutch died after 34000 miles or so. The clutch showed zero signs of wear until the day it gave up. SOMETHING TO KEEP IN MIND, FELLOW 5-SPEED OWNERS.
I'm fairly aggressive while driving. I'm not a fan of the lack of low-end torque, so I'd compensate by feathering the clutch with a little higher rpms (2k-3k on takeoff).
The dealer charged me $1400 to replace it. Ugh.
My old '00 Civic EX withstood a LOT more abuse than this car.
Old Jan 28, 2008 | 12:38 AM
coupdetat's Avatar
Oh jeez, I always start at around 2k rpm and let the clutch out. Is that not the correct way to start? I find that if I do any less, the car headlights will dim and I'll feel like it's bogging down!
Old Jan 28, 2008 | 12:39 AM
dank24's Avatar
that is pretty crazy. Oh well, when it goes hopefully excedy will have a stage 2 kit out.
Old Jan 28, 2008 | 05:45 PM
Posts in the NUUDE
I cant believe the clutches go at under 50,000miles. Thats REALLY early for a clutch to go out. My Mx-6 had the original clutch when I bought it, it was just going out. 107,000miles on the clutch.
The brake pads also go a little fast on these cars.
Old Jan 28, 2008 | 06:09 PM
dank24's Avatar
Yea I am really shocked as well. I had a cb7with 300k miles on the stock clutch.
Old Jan 28, 2008 | 06:18 PM
Posts in the NUUDE
The day my clutch goes out Ill be so pissed. I honestly dont know what Id do.
Hope I wont drive her into a tree.
Old Jan 28, 2008 | 06:21 PM
dank24's Avatar
mine is still tight and grabs well @ 24k miles. I could not see it going for another 20k miles, but who knows. If it does go honda is going to get bitched at hardcore from me, or the dealership. Cause I have bought 4 hondas from the same place without problems.
Old Jan 28, 2008 | 06:44 PM
coupdetat's Avatar
What's the best way to start from a standstill to preserve the clutch?
DaveD912
Mar 6, 2019 07:48 PM
Sono
Jan 29, 2018 07:54 AM
Shortcamo02
Jun 10, 2011 10:47 AM
couragethedog
Jul 24, 2008 03:57 AM
KentuckyFit
May 17, 2007 12:36 PM
