Fit's stability increases with speed?
i dont know if im dreaming or not, but it seems like if i go 60ish, the car seems to sway with crosswinds. But if i speed up to 70-80+, the car starts to feel more stable... Good aerodynamics or am i on drugs? :vtec:
the handeling is just really tight... i dont think it gets more stable... but you had better be 100% sober drivin this thing. on the way home from the dealership i lit a cig and looked up and had swerved all the way into the other lane... ive had it 5 months almost and i still swerve like im drunk all the time... this is the one car i couldnt ever really figure out. =\
I think the downforce helps but I don't think you will find better handleing at 80 rather then 60. And I have no problem driving mine, what do you mean you can't figure it out? What's to figure out?
I can't tell the difference because I'm using 205 tire width. Just be careful when there's Santa Ana winds...Also, I notice the stock wheels with dunlops don't stick as well as these Yokahoma summer tires. But turn radius is somewhat different between the tires.
the handeling is just really tight... i dont think it gets more stable... but you had better be 100% sober drivin this thing. on the way home from the dealership i lit a cig and looked up and had swerved all the way into the other lane... ive had it 5 months almost and i still swerve like im drunk all the time... this is the one car i couldnt ever really figure out. |
i think i know what you mean. Long before i had a fit my friend let me drive his Civic SI, and omg... I thought my mom's BMW 330i had direct steering... moving the steering wheel 1/100 of an inch made it go insane on the freeway! i didn't swerve off like you but i was having an extremely hard time trying to keep it on my lane, so i was swerving inside my own lane.. hahaha
i dont know how it compares to the Fit, but i came to like the Fit's steering alot. I can predict very well where the car is going if i turn this much. The only thing i dont like too much is the steering is a bit light compared to the BMW (i got over that) and also it seems as if it gets heavier when you go faster. I dont have a problem with becoming heavier, but it gets TOO heavy! :) |
Good thing the Fit is narrow!
Originally Posted by zRollerskate
(Post 318901)
Meanwhile, try to train yourself to look farther down the road ahead as you drive. The farther away your eyes are focused, the less you will be likely to drift. Good luck! |
Originally Posted by Steeldog
(Post 319072)
Any small car whose wheels are all the way out at the corners of the car will handle like this. Just have to get used to it.
car performs better under 65mph. :wavey: one of the main reasons why
i bought this car mainly for surface roads. |
i drive 50mph on the freeway because im usually in ecomode :P. but ive noticed that if i have the windows down *i don't put them down anymore* the car would be all over the place when its windy
(Post 319379)
dude, i roll with the windows UP and ac OFF. but i like to have a cold drink with me.
Wow. I didn't know you were an economiser. No wonder you get such good MPG with your manual Fit.
The fit is very stable I would say at highway speeds. The same places on the same freeways that made my IS350 get pretty rough (bouncing around, being tossed around) are no problem in my Fit. Specifically on I5 there’s a spot where the road transitions into different pavement with a big bump and probably 50 feet of heavy "gutters" (aka deep ruts from tires). I hit this spot every day and knew exactly where it was. In my IS350 I would almost be thrown into the lanes next to me at times. In my Fit, it just hits it and stays strait. On a lot of uneven road, the Fit is pretty damn strong. A lot of it might be the thinner tires but the suspension can tackle things like speed bumps pretty damn well. Not bad for such a short wheel base car.
| All times are GMT -4. The time now is 05:33 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
