Unofficial Honda FIT Forums
Unofficial Honda FIT Forums (https://www.fitfreak.net/forums/)
-   General Fit Talk (https://www.fitfreak.net/forums/general-fit-talk/)
-   -   Stock Sport PSI, What's Everyone Running??? (https://www.fitfreak.net/forums/general-fit-talk/27692-stock-sport-psi-whats-everyone-running.html)
7red7 Jul 5, 2008 04:18 AM
Hey there everyone!!! I'm curious to know what PSI everyone is running in their stock Fit Sport tires. I ask because with the USDM Fits having been around a while, there has to be some sort of agreed upon setting that gets the maximum MPG while still keeping that great handling ability. After about a month of ownership, my tires are in need of being reset, but I'd like to poll the audience and get some more opinions first :D
HAPPY DRIVING!!!
DAN
kenchan Jul 5, 2008 10:17 AM
when my car was stock (10 days?) i ran 32psi.
feddup Jul 5, 2008 10:28 AM
arguable
You'll get opinions all over the place. I believe the manual says 32 and the # on the side of the tire lists 51 as max. I tried out 40 cold as a "moderate" setting. The handling and ride are stiffer but I've gotten used to it. Frankly I've noticed very little difference on MPG. By the way there are many threads about tire pressure and you'll find the full spectrum of opinions except, I hope, people advocating running the tires very low. Good luck!
Sid 6.7 Jul 5, 2008 10:29 AM
Be prepared for some strong opinions on this matter. I would recommend doing a lot of personal research here and on the web in general before coming to a decision.
Here are a couple of threads to get you started:
https://www.fitfreak.net/forums/eco-fit/27513-45psi-tires-mpg-vs-34psi-tires-mpg.html
https://www.fitfreak.net/forums/fit-yourself-discuss-do-yourself-repair-maintenance/21875-ideal-tire-pressure-stock-sport-fit.html
https://www.fitfreak.net/forums/fit-shoes/26381-tire-pressure.html
7red7 Jul 6, 2008 03:40 AM
Thanks so much for pointing me in the right direction with those other threads :D
Unforgiven Jul 23, 2008 10:26 PM
I run the max pressure on the tire wall thanks to this article:
Driving Under Pressure: Editorial & Features at Officer.com
kancerr Jul 23, 2008 10:34 PM
haha yeah you will get a lot of STRONG opinions on this...i run 32. dont risk your life for saving 2 cents a mile...if you cant afford gas...dont drive.
Arashi Jul 23, 2008 10:59 PM
Honda says 32psi, run 32psi, they built the frickin thing, you trusted them enough for that, trust them for this!
Burbio Jul 24, 2008 12:54 AM
i run mine at 50 psi, and until i blow a tire i will continue to run at 50 psi. maybe that's one of the factors behind my recent 46 mpg tank average in my AT.
airborne200208 Jul 24, 2008 01:16 AM
1 Attachment(s)
I run 32 PSI just because I can afford an extra $2.00 worth of gas a week. My wife however let her Ridgeline's tires get low (20 PSI), hit a pot hole and this happened:
Attachment 79110
Firebat666 Jul 24, 2008 03:45 PM
im runing 45psi hot temp. getting 45mpg, ride is harsh but i dnt mind
Firebat666 Jul 24, 2008 03:46 PM
i run 45psi avging 43-45 mpg harsh ride but i dont mind
pb and h Jul 25, 2008 01:45 PM
60psi here for the last 1500miles, 50psi for the previous 15k and the rest was at 36psi. The ride is NOT cushy. If you want comfort and lower tread life follow HONDA's recommended pressure. If you want better mpg and longer tread life pump up the psi at least to the MAX side wall pressure. I have ~34k on the tires and not even close to the indicator wear bar.:p
Be OG and roll at 60! :D
Burbio Jul 25, 2008 01:53 PM
haha that's pretty funny
pb and h Jul 25, 2008 01:53 PM
I also rotate and balance my tires every 5-8K. With the increased pressure you will notice supreme traction for these tires.;)
Rockrover Jul 25, 2008 03:39 PM
51 psi here. Did it from the second day I owend the rig. I'm perfectly used to the ride now and don't notice the 'harshness'.
--D
© 2026 MH Sub I, LLC dba Internet Brands
