Tire rotation and TPM's
08 Sport Fit. In a few months i will need to rotate the tires. Do the TPM's need to be reset? I dont want any annoying light lit on the dash. Just doing front to back rotation, no crossing of tires.
If the TPM's need to be reset how much does it cost or is there an aftermarket resetter i could get for myself? :o Oh yea when does the voting start for calender pictures? |
I don't believe they will need to be reset. They should operate just fine. The light simply tells you if one of your tires has a low tire pressure, not specifically which one.
Excellant Glad i dont need to deal with the tpm's :D
Originally Posted by dc9mm
(Post 361225)
If the TPM's need to be reset how much does it cost or is there an aftermarket resetter i could get for myself? :o There is only one light on the dash and then it is up to you to figure out what one has the issue. Mine was the passenger rear, but yours may be different:D . Seriously, I just rotated this weekend and no issues at all. |
the RF modules need to re reset as they only work in the
direction it was programmed. :rotfl: now that is a lot of bs-ing. :D you'll be fine. the car's so silly it thinks the tires are on the car even if they are stacked up in your garage. :rotfl: |
Originally Posted by kenchan
(Post 361789)
hahaha :rotfl: he must have a electric grass trimmer.
| All times are GMT -4. The time now is 07:12 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
