Tire Pressure Monitor
My Tire Pressure monitor light is on. I have checked all the tire pressures and they are all at 32psi. Has anyone else had this problem
just wondering... is the pressure gauge your using good quality? if not that could be your problem
Yep, it is a good one not one of those dtick type
odd but necessary quetion hwere..are you still using th OEM rims?
Originally Posted by Injundon
(Post 415218)
Take it to the dealer.. this can happen after rotating your tires, or if a clip came loose, tire pressure anywhere from 28PSI-35PSI should not register any faults.
Yea, I set up a time to take it in the only wat to find out
I run 38 psi, my light recently came on when one tire (right rear) pressure got below 28psi
Originally Posted by ChefMark
(Post 415227)
The light with the tire and "!" means that the system is registering a flat tire, if it's the "TPMS" light, it means there is a problem with the tire pressure monitoring system itself.
Originally Posted by Tofuman
(Post 415820)
Originally Posted by stickyricebandit
(Post 417028)
that light come on one morning before i left for work. checked it out and drove off (i was running a bit late to check the pressure) After work I went to go home and the light was no more :confused:
Since the light came on in the morning my best guess is that your tire pressure COLD is too low. Might need to inflate them a bit. |
