Do u guys think it they will fit on my fit?
If the wheels have a 4x100 bolt pattern, then yes.
Both generation Fits have the same bolt pattern. The GE8 is rumored of having a Mugen version coming to the US with the Aluminum Wheel XJ installed and the GD3 would also be able to fit either rim because the factory rims are wider that both of those Mugen rims even with a +42 offset. |
the new ge8 mugen edition released at SEMA comes with these wheels. yes they do work.
thanks for the info , actually i cant read the page cause i cant install the language packages , what bout the NR will they fit?
they will fit too. illusive used to have a set on his fit. as long as the offset is in the 40s you should be ok with no rubbing.
Sure they'll fit on a GD3, but I don't know about the GE8 though. I'm thinking more than likely if Honda didn't change the disc and/or caliper size for the brakes.
any wheel that fits the ge8 will definately fit the gd3 but i dont think it works the other way around.
