Just to be clear, the Maintenance Minder wouldn't know dino or synthetic - you'll still get the same % either way. irst oil change should NOT be done early. The break-in oil has more molybdenum in it, Modern engines building has really improved and most engines are fully broken in at 600-1000 miles. Hell, even the old school engines were broken in at 1200-1500 miles. The things that takes the longest to break in are the rings and they seat within the aforementioned time frame if not sooner. Don't believe me, go do a leak down test on your engine. So waiting for the full life is a waste of time and if anything allows the dirty break in oil to possibly do more damage. The only reason we use crappy break in oil is so that parts CAN wear together to break in (mostly rings to cylinder walls), then we can use the best synthetics of our choice. |
I have a M/T Sport with over 4200 miles on it - the oil life is still at 70%. So the manual models are capable of high mileage between changes not just the A/T models.
Of course you can. I'm just repeating the words of the engineers at Honda. Take it up with them.
I just go with what the oil filter brand recommends. I don't think the oil will break down that easy on the fit, but if the oil filter is clogged, then doesn't matter if oil is good or bad, there might not be enough in the engine to protect the engine.
Mercedes and Jag both change ALL oils at 1000 km to get the grindings from new parts wearing into each other OUT of the engine, trans, and rear end. MyFit will have 1500 on it by the end of the month when I out on snow tires. I feel bad that I havent changed my oil yet. Good Grief, its just oil in a little Jap engine. In the largest of pictures, all that matters is to keep clean oil in there! Rotella T synthetic for me
Two Oil Changes So Far
My 2013 Base A/T is now almost 15 Months old. Just did my 2nd oil change, both oil changes were done at MM 15%, 1st oil change 7,569 mi, 2nd oil change 6,924 mi.. Not sure if I should worry about it coming a little faster the 2nd time around or not? I see a lot of 10,000 mile's out there? But I drive 2/3 city, 1/3 highway. Not a grandma, but not a lead foot either.
with my 10 sport and my 13 I was within 100 miles of 10000 for every oil change after break in. on my 10 i went in @ 3000 because I heard (I think in manual) 1st change should be done early. the dealership scolded me that I should follow the minder. They also told me I needed an alignment and didn't after i got a second opinion. So I did an early change 1st time on my 13 too. Not that I am right but this has been my experience. Feel weird about going 10000 before a change though. I also no longer go to that dealership
The maintenance minder is based on the factory filled oil so if your fit came with dino oil like the 5W20 then its accurate. If your Fit came with synthetic 0W20 like mine did and you put conventional then it is NOT accurate. There is no oil sensor.
Originally Posted by spin out
(Post 747439)
since my last oil change, i've driven 6635 miles and my minder says i have 50% oil life left (im sure it'll hit 40% very shortly).
i drive normally. i dont push the car, i dont baby the car. based on the maintenance minder, i could go close to 10,000 miles before needing an changing oil. ive heard the oil life minder is simply calculated by engine revs. i dont know if that's true... but it makes sense. i plan to change the oil at 7000 miles... but i wonder if i really have to. |
Blinking Oil Indicator
So I went to -19 after my oil reached 0%. I commute in very hot weather so I have to change my oil every 5k. I had never let it slip below 15% but was laid off recently and avoiding spending the money. Finally had the oil changed yesterday and they didn't reset the indicator. Now it's just blinking that negative number at me and I can't figure out how to make it stop. I tried resetting it but it didn't work. I feel like a helpless girl and helpless I rarely am. HELP!
Originally Posted by Lehuber89
(Post 1346971)
Originally Posted by Uncle Gary
(Post 1347104)
The owner's manual tells the procedure to reset the maintenance minder. Turn on ignition, press trip odometer reset knob repeatedly until the oil life screen is displayed. Press and HOLD the reset knob for 10 seconds. The display will flash and the next service code will be displayed. Press and HOLD the reset button again for 10 seconds and the maintenance minder will reset to "100%".
(Post 1347107)
Yeah, i tried that. Couldn't get it to work. The display doesn't STOP flashing. It's not displaying the oil life anymore, it's just displaying the miles I've gone since dropping below 0%. The reset isn't working. Any other suggestions?
Also, ten seconds can seem to be a lot longer than it should by rights when you're holding a dinky little button in. The procedure does work, even if you're in the negative/past due zone. |
