anyone use a ultragauge?
Old Feb 3, 2012 | 06:18 PM
1bluefit's Avatar
I just got mine hooked up today. My question is on the coolant temperature. Mine is reading around 170 after the car warms up and I know that is low. I want to know what readings other users of this gauge are getting. Is it because of where it gets the readings from? If not I guess its time for a thermostat.
Old Feb 3, 2012 | 07:00 PM
einstein77's Avatar
The thermostat on the Fit is 180 F. You're not really far off and it may be due to the outside air temperatures. The thermostat will stay closed until 180 F. I have a scangauge that monitors that. My car is a constant, after warmup, of 179 F. My car is the GD 08.
Old Feb 3, 2012 | 07:18 PM
Subie's Avatar
Ultragauge thread
ibluefit, here's an ultragauge thread you might be interested in reading:
https://www.fitfreak.net/forums/gene...tml#post980253
Old Feb 4, 2012 | 01:26 AM
Virrdog's Avatar
Mine hovers around 176 depending on what I am doing.
So, that's completely normal.
Old Feb 5, 2012 | 09:18 PM
1bluefit's Avatar
Thanks Subie for the link! Thanks to all with answers on the engine temp. I am now having kind of a problem with the set-up on the ultragauge. When I go to set what gauges I want I don't get the alphabetical zones. All I get is the different screen numbers of 1-8. I can't for the life of me find out what I have done wrong.
Old Feb 23, 2013 | 08:03 AM
Logans07Fitty's Avatar
If anyone is considering buying one of these I WOULD HIGHLY RECOMMEND GETTING ONE! I spent around $89.00 with two mounts and shipping and possibly tax. It got here really quick and you buy it directly from them. They also offer a 9.00 rebate but omg it's a freaking hassle they make you jump through a done of hoops for 9$.
Anyways it literally does everything you can think of. Clears CEL lights and can tell you temps on anything with a sensor. Best part is LOD and MPG.
Old Oct 23, 2015 | 01:28 PM
john21031's Avatar
Only problem, it creates a small draw on the battery and unlikely to drain it overnight but over a weekend it's gonna be a significant drain. It will shorten the life of the OEM battery so that is why I unhooked mine.
I've measured the draw and it's about 30 extra milli amps
Bugzs15
Oct 28, 2013 02:37 AM
Klasse Act
May 5, 2010 04:45 PM
michaelfit84
Jan 17, 2009 03:53 AM
Batman
Dec 1, 2007 05:54 PM
tmixdorf
Sep 27, 2005 03:30 PM
