Dynamat on firewall?
Considering peeking under the car and seeing what kind of firewall surface behind the engine might benefit from some Dynamat* for sound deadening.
Much easier to access than the interior. Surface far dirtier, will have to be cleaned. Dynamat is safe up to 300+ degrees so fire is a low risk, but because the butyl could soften I won't be putting any near or above the exhaust hardware. Thoughts? *Noico, actually. Knockoff Dynamat. Still quite effective IMO :D |
Originally Posted by fujisawa
(Post 1416826)
Much easier to access than the interior. Surface far dirtier, will have to be cleaned. Dynamat is safe up to 300+ degrees so fire is a low risk, but because the butyl could soften I won't be putting any near or above the exhaust hardware. Thoughts? *Noico, actually. Knockoff Dynamat. Still quite effective IMO :D 3M noise pads - not sure if this is buytl based https://www.3m.com/3M/en_US/company-...3193969&rt=rud Paint on option - no worries about sticky stuff https://www.3m.com/3M/en_US/company-...3241345&rt=rud Install on inside of firewall https://www.3m.com/3M/en_US/company-...2659042&rt=rud |
It would be far easier to stuff some deadening material in the dash cavities.
