Muffler place
Hey guys, hoping you are checking Fitfreak today:D
I am wondering if any of you know of an exhaust shop that is open today and could weld a bung in an oem header for me? Nick I remember you had a look into this but not sure if you ended up going on a weekend. |
Crowfoot Muffler isn't open on the weekend, they are the cheapest place I found that wasn't going to screw me around. I think it was 12$ to put it in.
Here was my rant about it;
Originally Posted by Sugarphreak
(Post 585552)
Man, all the responces from muffler shops today have been piss poor except for Crowfoot Muffler. I guess I will try to book it down to Crowfoot after work today... at rush hour... in the snow :(
I think my favorite was either Midas or Speedy Midas: Hello Me: Can you guys install a weld in bung on a header for me this afternoon? Midas: Well a weld in bung eh, that could take a couple of hours to install Me: But it is a header that is a loose part I will bring in, it has never been installed and is totally clean. Midas: But you know, cutting the whole and depending on where it gets installed it could be tricky... at least an hour or two worth of labour. Me: um ok... never mind Speedy: Hello how can I help you Me: Hi, can you guys install a weld in bung for me on a new uninstalled header? Speedy: Sorry we don't install supplied parts Me: Well they are both loose parts, but you guys could supply the bung... Speedy: *Click* |
I paid $38 and minute muffler on mcleod installed one.
Now I need a stupid M18X15 tap because the idiot welding wasn't careful and a little bit of splash went on the threads and the o2 wont go in more than halfway... |
They didn't have the plug in when they welded???
nope great stuff eh? :P
It can apparently warp the bung when they weld and screw it up, the Crowfoot shop gave me sh!t about it when I didn't supply the plug right away.
great stuff :P
I think mine is ok because it threads the o2 half way but once it gets to that point it wont go further. I almost destroyed the threads on one of my 2 o2 sensors thrying to hammer it past that point :( Hopefully I get a tap today for that and can fix it. |
That sucks man,
I would lend you a tap & dye set... if I had one :wavey: |
