DRL fuse #???
I removed this fuse long time ago ever since I installed my HID
I want to put the fuse back now but I forgot what socket # in the panel also I can't remember its 15 amps or 20 amps. anyone know the answers please? I check the manual and its not there. |
I'm assuming that DRL is referring to the door lock relay. If so it is a 20 amp fuse and number 28 in the dash fuse box.
I'm not sure which model you have, or if this info pertains to all models. If you mean daytime running lights, then it's a 7.5 Amp fuse in location 15. My info came from the 2010 owners manual.
Originally Posted by Rampo
(Post 1103705)
sorry I didn't provide enough information, its my fault.
I got a 2010 GE sport model and DRL (day time running light) is only available in Canada so for US FIT members, your electrical panel might be different. I am not sure That's why I post this in the Canadian forum area, thanks guy. |
Originally Posted by alanchan
(Post 1103708)
sorry I always thought US model don't have DRL
Fuse 15 methinks
it should say on the map on the back of the cover
