Digital Torque Wrench - Member Special
http://www.brownlinemetalworks.com/images/wrench.jpg
As a new vendor on this forum, we are offering an introductory special: our Digital Torque Wrench w/ Blow Molded Case for $99 - including shipping. Just go to our website: Brown Line Metalworks, LLC | Professional Grade Digital Torque Wrench and click on the "Buy Now" button. At checkout, enter the coupon code: FREAK You can see the torque wrench in action in the following video: Brown Line Metalworks Digital Torque Wrench - YouTube Product Specifications Patented Double Gear Sensing System Designed, engineered, and tested by Brown Line Metal Works, the patented* D.G.S.S. technology ensures repeatable accuracy of +/- 3.5% both clockwise & counter-clockwise Accurate from 20 – 100% of full scale (7% accuracy from 10 – 20% of full scale) Microprocessor Controlled 8-bit electronics ensures accurate readings and simplicity of use Allows for both Peak and Track mode Individually calibrates each wrench Supplies unique serial number for each wrench Ratchet Head 1/2" drive reversible ratchet 32-tooth gear provides an 11.25º arc while handling high torque loads Forged from Chromium Vanadium alloy to ensure strength Conforms to ASME B107.10 2005 standards Range 15 – 150 ft/lbs 180 – 1,800 in/lbs 20.3 – 203 Nm Digital Control Large backlit digital display shows both target torque and current read-out Intuitive button design makes operating torque wrench simple LEDs and digital display provide visual feedback when operating wrench Buzzer creates audible feedback when target torque is reached Easily switch between ft/lbs, in/lbs, and Nm Automatically powers off when not in use for 2 minutes Low battery indicator Handle Soft-touch overmold provides comfortable non-slip grip Engineered plastics ensure an impact resistant housing The offer is valid until Feb. 18th, and is only for the lower 48 states. |
22 days left !!
16 days left.
what is the price? what is the warranty?
The lower 48 states suck!
Free bump. |
(Post 1071025)
Warranty is industry standard: 1 year from date of purchase, 90 days for calibration. Our repair / calibration facility is located in Chicago in case anything ever does need to be done to the wrench. BLMW |
3 Days Left !!
ordered one today. what other tools will you hope to introduce in the future?
Originally Posted by Fit4DHM
(Post 1074384)
BLMW |
Last day!!
