Re: 2005 Accord ... Should I?
Early pad wear is a result of the TCS, turn it off and you will find that
the pads last longer and the car performs better. <jmattis@attglobal.net> wrote in message news:1107368261.788017.236400@l41g2000cwc.googlegr oups.com... > > DaveR wrote: >> My lease is nearly up on my 2002 Accord. I've been leasing accords > for >> 8 years now. But this last one had some issues ... it needed a new >> transmission (and even the new one is showing some early symptoms of >> trouble). The brakes also wore down at about 25K, earlier than any >> other Accord I have owned (though I can't be sure it wasn't my >> driving). >> >> I've been a loyal Accord driver for many years ... any reason not to >> consider the 2005 model? Has Honda finally fixed the Accord >> transmission problems? > > The early pad wear (on the rears) is a common complaint with the > current model, but partially is determined by driver habits. On the > other hand, it's easy to fix and the dealer has to make money from > something. Just another small part of car ownership. I had an '90 > Integra that made it 105,000 miles on all the original pads, though. > Nice. My gf (now wife) also had a '90 Integra, but she burned through > pads every 30,000. > > They've probably got the tranny problem licked too. Reportedly the > 2006 mid-model change will revise quite a bit of the exterior -- that > would dampen my interest somewhat, but if your lease is up, ya gotta do > something regardless. > > JM > |
On Fri, 04 Feb 2005 04:28:31 GMT, "PMS" <pms65@sbcglobal.net> wrote:
>Early pad wear is a result of the TCS, turn it off and you will find that >the pads last longer and the car performs better. How do you turn it off? It seems TCS comes on automatically when needed, i.e. when the car is skidding. I have on occasion turned it on manually when driving in slippery conditions, but otherwise I let the car deal with it. |
"DaveR" <NOSPAM_drubin@NOSPAM_i-2000.com> wrote in message
news:W6UDQrPwLd6dCQ16BDd6TeP1exOJ@4ax.com... > On Fri, 04 Feb 2005 04:28:31 GMT, "PMS" <pms65@sbcglobal.net> wrote: > >>Early pad wear is a result of the TCS, turn it off and you will find that >>the pads last longer and the car performs better. > > How do you turn it off? It seems TCS comes on automatically when > needed, i.e. when the car is skidding. > > I have on occasion turned it on manually when driving in slippery > conditions, but otherwise I let the car deal with it. The TCS button turns it off. |
On Fri, 04 Feb 2005 16:40:47 GMT, "Seth"
<seth_lermanNOSPAM@hotmail.com> wrote: >"DaveR" <NOSPAM_drubin@NOSPAM_i-2000.com> wrote in message >news:W6UDQrPwLd6dCQ16BDd6TeP1exOJ@4ax.com... >> On Fri, 04 Feb 2005 04:28:31 GMT, "PMS" <pms65@sbcglobal.net> wrote: >> >>>Early pad wear is a result of the TCS, turn it off and you will find that >>>the pads last longer and the car performs better. >> >> How do you turn it off? It seems TCS comes on automatically when >> needed, i.e. when the car is skidding. >> >> I have on occasion turned it on manually when driving in slippery >> conditions, but otherwise I let the car deal with it. > >The TCS button turns it off. When I press the TCS button the dashboard light comes on. So I assume TCS is OFF by default. The only other time the TCS dashboard light comes on is when I'm skidding. |
news:JKYDQmDxRgkTrutxvn=g85fhHQD+@4ax.com... > On Fri, 04 Feb 2005 16:40:47 GMT, "Seth" > <seth_lermanNOSPAM@hotmail.com> wrote: > >>"DaveR" <NOSPAM_drubin@NOSPAM_i-2000.com> wrote in message >>news:W6UDQrPwLd6dCQ16BDd6TeP1exOJ@4ax.com... >>> On Fri, 04 Feb 2005 04:28:31 GMT, "PMS" <pms65@sbcglobal.net> wrote: >>> >>>>Early pad wear is a result of the TCS, turn it off and you will find >>>>that >>>>the pads last longer and the car performs better. >>> >>> How do you turn it off? It seems TCS comes on automatically when >>> needed, i.e. when the car is skidding. >>> >>> I have on occasion turned it on manually when driving in slippery >>> conditions, but otherwise I let the car deal with it. >> >>The TCS button turns it off. > > When I press the TCS button the dashboard light comes on. So I assume > TCS is OFF by default. It's on by default. The light is a reminder that it is disabled. > The only other time the TCS dashboard light comes on is when I'm > skidding. The flashing TCS light means it is actively working on an issue (skidding). Have you look in the manual? It is clearly spelled out. |
