Re: 2004 Odyssey shuts off when stopped
I just had our 2004 Odyssey serviced under a recall notice related to the
fuel pump connector. The recall postcard we received said that if the connector began to corrode, the car could stall. I don't know if it is related, but you may check into that if you haven't had your car serviced for this recall. Good Luck! "mmhamilton" <mmhamilton@verizon.net> wrote in message news:Xns95F14D5422527mmhamiltonverizonnet@199.45.4 9.11... > My wife's 2004 Honday Odyssey (6K miles) sometimes just shuts off when she > comes to a stop. No lights on the dash or anything. It only happens once > or twice per day. This started happening at around 5K miles. She also > said it happened while she was moving slowly one time which is really what > scares me. I took it to the Honda dealership and they could not get it to > replicate. They did an Idle Relearn, checked for air leaks and sensor > connections and found no problems. > > I've called and scheduled another appointment with the dealer, but the > problem is getting this to happen on command. The guy wasn't too thrilled > and said he can't have a tech driving around all day. I'm just looking for > some suggestions as to what could be causing this and how I should pursue > this. Could it be a faulty ignition switch? Idle Problem? Does this fall > under Lemon laws? I bough the car in PA and it is registered in WV so I'll > have to research where this falls. Thanks for any input :) |
