Three Questions..
I own a 95, integra.
1/. I need to do my brakes on my car, I've seen my buddy do his brakes and it looked like a snap, he had a ford pick up, I'm wondering.. since I have to replace the pads and rotors on my brakes, do I have to worry about alignment of the caliper or anything or will this be relatively as simple as throwing in the rotors and pads.. 2/. I have a wire that has come loose in the dash somewhere and it's vibrating against something and dash. How hard is it to remove the dash to get access to this? also the lights are out in the speedometer area, so I'd replace that while I'm at it. 3/. the antena motor has disconnected from the actual antena. So the motor runs when I turn the car on and off, but the antena does not move. How hard is this to fix? and what do I need to do? thanks, Eric |
Re: Three Questions..
Eric wrote: > I own a 95, integra. > > 1/. I need to do my brakes on my car, I've seen my buddy do his brakes and > it looked like a snap, he had a ford pick up, I'm wondering.. since I have > to replace the pads and rotors on my brakes, do I have to worry about > alignment of the caliper or anything or will this be relatively as simple as > throwing in the rotors and pads.. > > 2/. I have a wire that has come loose in the dash somewhere and it's > vibrating against something and dash. How hard is it to remove the dash to > get access to this? also the lights are out in the speedometer area, so I'd > replace that while I'm at it. > > 3/. the antena motor has disconnected from the actual antena. So the motor > runs when I turn the car on and off, but the antena does not move. How hard > is this to fix? and what do I need to do? > > thanks, > > Eric click on www.tegger.com for a good FAQ page there are a least two very good pages on breaks, and lots of other interesting stuff. If that URL does not work for you just do a Google search for tegger.com. ( I have had some trouble sending URLs in this newsgroup but I think it is fixed) Ernie |
