97 Accord brake job makes scraping noise
Replaced the front rotors on my 97 Accord (big job) due to it having a
serious rotor warping. Utilized Honda rotors. The pads were also ready to be replaced. It looks like the previous owner had the cv joint boots go on both sides and there was a serious amount of old grease everywhere. I'm guessing that riding on grease created the heat that warped the original rotors. Anyways after puttin on new pads and torqing everything down on the test drive there is a lot of scraping noise. The calipers look pretty nasty even after a good cleaning. Is it possible the seals in the calipers couple be fried? What else could be the problem? Thanks Greyhound Tampa, FL |
Re: 97 Accord brake job makes scraping noise
On Sun, 01 May 2005 05:13:41 GMT, "Grey-hound"
<grey-hound@"removethis"verizon.net> wrote: >Replaced the front rotors on my 97 Accord (big job) due to it having a >serious rotor warping. Utilized Honda rotors. The pads were also ready to be >replaced. It looks like the previous owner had the cv joint boots go on both >sides and there was a serious amount of old grease everywhere. I'm guessing >that riding on grease created the heat that warped the original rotors. >Anyways after puttin on new pads and torqing everything down on the test >drive there is a lot of scraping noise. The calipers look pretty nasty even >after a good cleaning. Is it possible the seals in the calipers couple be >fried? What else could be the problem? A common cause of rotor warping is corrosion between the hub plate and the rotor, especially if the hub plate has holes in it which some Hondas do. Did you clean up any corrosion on the hub plate surface thoroughly and make sure the new rotor was not rocking on the plate when mounting? You mean scraping on brake application? Some scraping/scuffing noises from new pads and rotors is normal IME for a few miles. If it doesn't clear up after driving for a while, check the outer rotor surface for evidence. -- Rgds, George Macdonald |
I wire brushed off any corrosion that I found. The scraping noise is when I
do not have my foot on the brake and appears to be coming from both front brakes. When I apply the brakes it gets louder. Maybe you are right since it is coming from both front brakes that some break in is required. The last set of rotors I put in on my 300ZX were Chinese rotors and I roughened them up with some emery cloth because they looked too shiny-maybe I should have done the same with them. "George Macdonald" <fammacd=!SPAM^nothanks@tellurian.com> wrote in message news:6lv971llekci8jjko4tkh0odvcn7l0ot3d@4ax.com... > On Sun, 01 May 2005 05:13:41 GMT, "Grey-hound" > <grey-hound@"removethis"verizon.net> wrote: > >>Replaced the front rotors on my 97 Accord (big job) due to it having a >>serious rotor warping. Utilized Honda rotors. The pads were also ready to >>be >>replaced. It looks like the previous owner had the cv joint boots go on >>both >>sides and there was a serious amount of old grease everywhere. I'm >>guessing >>that riding on grease created the heat that warped the original rotors. >>Anyways after puttin on new pads and torqing everything down on the test >>drive there is a lot of scraping noise. The calipers look pretty nasty >>even >>after a good cleaning. Is it possible the seals in the calipers couple be >>fried? What else could be the problem? > > A common cause of rotor warping is corrosion between the hub plate and the > rotor, especially if the hub plate has holes in it which some Hondas do. > Did you clean up any corrosion on the hub plate surface thoroughly and > make > sure the new rotor was not rocking on the plate when mounting? > > You mean scraping on brake application? Some scraping/scuffing noises > from > new pads and rotors is normal IME for a few miles. If it doesn't clear up > after driving for a while, check the outer rotor surface for evidence. > > -- > Rgds, George Macdonald |
