Spark Plug Hex Nut Disintegrated
Old May 18, 2005 | 11:20 PM
Carl Gerhold
Guest
Posts: n/a
Weird, Weird problem...I pulled the #4 plug wire and slid the plug puller
down the tube and it just spins when rotated. I shined my light down the
tube and the hex nut is gone. The plug wire plastic connector had reddish
brown discoloration. It's a '94 Accord EX 149K miles. I changed the plugs
with NGK's last year @ about 132K with no problems. The wires have never
been changed. The car still runs fine but I'm guessing this could a huge
problem. Does anyone know what the source of the malfunction could be? Any
clues on how to remove the plug? TIA.
Carl
jim beam
Guest
Posts: n/a
Re: Spark Plug Hex Nut Disintegrated
> Carl
it can't be "gone". it's at the bottom of a blind 6" hole with a socket
blocking the end. even if the hex were mysteriously separated from the
rest of the plug [/most/ unlikely given that the plug metal is cold
formed from a single chunk of quality steel] it would still be in there.
much more likely is that you have something like an old plug lead
rubber or socket rubber covering it. pull as much as you can out with a
hooked wire coathanger, then look for the hex again. it'll be there.
Carl Gerhold
Guest
Posts: n/a
JB, thanks for the reply. Now I know where the missing socket rubber ended
up. We were heading out on vacation and I was pushing it on time and just
didn't pay attention. I'll pick away at it tomorrow.
"jim beam" <nospam@example.net> wrote in message
news:47CdnRZddo_gaRbfRVn-tg@speakeasy.net...
puller
the
reddish
plugs
never
huge
Any
> > Carl
Old Dec 13, 2020 | 11:10 PM
Francisco Ogura's Avatar
Thank you so much. I had the same problem wherein the hex nut disappeared.
With a solid wire, shaped as a hook, I was able to remove a rubber ring that belonged to the spark plug removing/installing tool. Actually, this very rubber ring was on the way to see the hex nut.
Triskelion
Sep 23, 2022 02:58 AM
justanewbie
Feb 1, 2020 05:12 PM
Deer
Oct 5, 2017 07:28 PM
mxl180
Jul 14, 2012 07:42 PM
sLiVeRwOrM
Oct 25, 2007 02:22 PM
