ABS Warning light
Hi All,
I am cross posting this here since Honda Passport and Isuzu Rodeo are prety much identical. I have a 2000 Rodeo LS 4X4. Recently my ABS warning light (Orange) coming on and couldn't reset it. Not sure which wheel sonsor is the culprit. Local Isuzu dealer would charge $85 to identify where the problem is. Unfortunately, the warranty period is over and I don't feel like spending $85 + the repair cost. If I can get some help from you guys to identify the problem, I may be able to get OEM parts or from the junkyards. Local AutoZone has OBD readers but not for ABS Warnings. Any help is appreciated. Thanks in advance. Mathew |
Re: ABS Warning light
MattA wrote:
> Hi All, > > I am cross posting this here since Honda Passport and Isuzu Rodeo are > prety much identical. I have a 2000 Rodeo LS 4X4. Recently my ABS > warning light (Orange) coming on and couldn't reset it. Not sure which > wheel sonsor is the culprit. Local Isuzu dealer would charge $85 to how do you know its a sensor, as opposed to the pump or whatever? just curious. > identify where the problem is. Unfortunately, the warranty period is > over and I don't feel like spending $85 + the repair cost. If I can get > some help from you guys to identify the problem, I may be able to get > OEM parts or from the junkyards. > > > Local AutoZone has OBD readers but not for ABS Warnings. Any help is > appreciated. a helm manual might help locate/troubleshoot the problem. id be tempted to take em all out one at a time and clean/examine em, if possible. i dont know if a voltmeter would help give a reading, or not. > > > Thanks in advance. > > > Mathew > |
You need to find out which code(s) are stored before you do anything.
Professor www.telstar-electronics.com MattA wrote: > Hi All, > > I am cross posting this here since Honda Passport and Isuzu Rodeo are > prety much identical. I have a 2000 Rodeo LS 4X4. Recently my ABS > warning light (Orange) coming on and couldn't reset it. Not sure which > wheel sonsor is the culprit. Local Isuzu dealer would charge $85 to > identify where the problem is. Unfortunately, the warranty period is > over and I don't feel like spending $85 + the repair cost. If I can get > some help from you guys to identify the problem, I may be able to get > OEM parts or from the junkyards. > > > Local AutoZone has OBD readers but not for ABS Warnings. Any help is > appreciated. > > > Thanks in advance. > > > Mathew |
MattA wrote:
> Hi All, > > I am cross posting this here since Honda Passport and Isuzu Rodeo are > prety much identical. I have a 2000 Rodeo LS 4X4. Recently my ABS > warning light (Orange) coming on and couldn't reset it. Not sure which > wheel sonsor is the culprit. Local Isuzu dealer would charge $85 to > identify where the problem is. Unfortunately, the warranty period is > over and I don't feel like spending $85 + the repair cost. If I can get > some help from you guys to identify the problem, I may be able to get > OEM parts or from the junkyards. > > > Local AutoZone has OBD readers but not for ABS Warnings. Any help is > appreciated. > > > Thanks in advance. > > > Mathew ------------------------- First, determine if it happens only if the vehicle is moving. If it can sit on the driveway and idle for five minutes and not generate a light, it's probably a wheel sensor. Once you start moving, the system looks for a clean signal from all four sensors (as well as the speed sensor). Inspect the tone rings on the front for obvious rust / dirty grease accumulation. Knowing your mileage is a help too. Have the brakes been bled according to the schedule? 'Curly' |
Thanks for the info. My vehicle has 65K on it. The ABS warning light is
stale all the time. The moment you start the vehicle it comes on and I don't have to drive. For the last two weeks it was on and off ocationaly. Now, it will not go away. I can rule out the rear since the rear brakes were changed 2 month ago and I did not get any warning at that time. My suspecion is the front. I bought this vehicle as used and not know all the history. The braking part is working find just the warning light is concerning me. I can ask my mechanic to bleed and see whether it solve the problem. I have the Haynes manual but there is nothing about ABS sensor or speed sensor. I don't even know how it would looks like. Is there any web link I can check for additional info? Appreciate your help. Mathew |
"MattA" <matta@ipass.net> wrote in message
news:1117582109.590977.322110@g47g2000cwa.googlegr oups.com... > Thanks for the info. My vehicle has 65K on it. The ABS warning light is > > stale all the time. The moment you start the vehicle it comes on and I > don't > have to drive. For the last two weeks it was on and off ocationaly. > Now, it > will not go away. I can rule out the rear since the rear brakes were > changed > 2 month ago and I did not get any warning at that time. My suspecion is > the > front. I bought this vehicle as used and not know all the history. The > braking part is working find just the warning light is concerning me. I > can > ask my mechanic to bleed and see whether it solve the problem. I have > the > Haynes manual but there is nothing about ABS sensor or speed sensor. I > don't > even know how it would looks like. If the ABS light is going on before you roll, then it is most likely NOT a wheel sensor. They haven't been exercised at that point, so can't show fault. Pump or ECU would be my suspicion. |
On Wed, 01 Jun 2005 00:13:48 GMT, "Seth"
<seth_lermanNOSPAM@hotmail.com> wrote: >"MattA" <matta@ipass.net> wrote in message >news:1117582109.590977.322110@g47g2000cwa.googleg roups.com... >> Thanks for the info. My vehicle has 65K on it. The ABS warning light is >> >> stale all the time. The moment you start the vehicle it comes on and I >> don't >> have to drive. For the last two weeks it was on and off ocationaly. >> Now, it >> will not go away. I can rule out the rear since the rear brakes were >> changed >> 2 month ago and I did not get any warning at that time. My suspecion is >> the >> front. I bought this vehicle as used and not know all the history. The >> braking part is working find just the warning light is concerning me. I >> can >> ask my mechanic to bleed and see whether it solve the problem. I have >> the >> Haynes manual but there is nothing about ABS sensor or speed sensor. I >> don't >> even know how it would looks like. > >If the ABS light is going on before you roll, then it is most likely NOT a >wheel sensor. They haven't been exercised at that point, so can't show >fault. > >Pump or ECU would be my suspicion. follow the wires from the rear sensors, they will end up on the drivers side near the rear of the fuel tank at a 2 pin connector. i've seen a lot of them where the wires are broken right there. best i can do with out a code. Chip |
