Shock absorber bushing
Old Jun 3, 2005 | 01:06 AM
B-Nut
Guest
Posts: n/a
I have a 1988 honda accord dx 5 spd manual carb. I replaced the driver side
strut and coil spring. but as I began the job, I noticed i had a broken
bolt that connects the lower control arm to the damper fork. I bought a
replacment bolt, nut, and bushing. But my problem is how do i get the
bushing out of the control arm to install the new one? Is there a special
tool I need? somebody give me some direction to follow.
Nightdude
Guest
Posts: n/a
Re: Shock absorber bushing
A torch! That's how my mechanic removed bushing from arms. Or maybe a press.
I would have changed mine long time ago, they are cheap to buy, but the
$#)$(#) job to do that is $$$ or lots of cursing and swearing if you do it
yourself without the right tools.
"B-Nut" <cassanova_44004@yahoo.com> wrote in message
news:df3c65472b7bd984876200283917add7@localhost.ta lkaboutautos.com...
jim beam
Guest
Posts: n/a
bearing press. but if you broke the bolt, can't you just replace the
bolt, not the bushing?
Steve Bigelow
Guest
Posts: n/a
"jim beam" <nospam@example.net> wrote in message
news:1eKdneDYCM4VGAPfRVn-sQ@speakeasy.net...
>> side
They seize in the bushing. Drill out the rubber in the bushing enough to
twist out that portion, then take a sawzall to the outer bit. The new ones
will hammer in with the correct size socket.
oiric2006@gmail.com
May 2, 2018 12:18 AM
apexanimal
Mar 23, 2014 02:45 PM
Kuturagi
Mar 29, 2012 04:25 AM
MatT3T4
18
May 26, 2011 11:38 PM
TeGGer®
May 4, 2005 04:44 PM
