how to get bolt out from civic alternator?
Old Jul 9, 2005 | 06:03 PM
Rocky
Guest
Posts: n/a
I have been using pb blaster, but the bolt will not slide out from the lower
mounting of the alternator - 94 civic lx. I can't even move the alt by
hand, so I have been using a prybar and large sledge hammer - then it moves,
but won't free up enough to release the through bolt.
I guess Honda didn't expect the car to be driven in snow and salty roads
when they decided to put the alternator low and next to the front tire when
it will get splashed. It also would have made more sense to use a
serpentine belt instead of 3 separate belts for the accessories.
Old Jul 9, 2005 | 06:36 PM
Professor
Guest
Posts: n/a
Re: how to get bolt out from civic alternator?
Use a penetrating oil and apply heat carefully to the area. This should
break the bond. Be patient... and repeat the process until you get it.
Professor
Check out FlashAlert at www.telstar-electronics.com
Old Jul 9, 2005 | 08:24 PM
Rocky
Guest
Posts: n/a
Would a propane torch get hot enough?
"Professor" <briangriffey@sbcglobal.net> wrote in message
news:1120946982.113744.67450@g14g2000cwa.googlegro ups.com...
> Professor
Old Jul 10, 2005 | 06:19 PM
Rocky
Guest
Posts: n/a
update:
I bought a 4' long hose/propane torch fitting kit and have heated up the
bolt til it starts to glow and the alternator starts smoking from the
windings buring - that lower bolt still will not loosten.
I am howerver able to freely flop the alternator back ond forth in it's
pivot - the rust have disolved in that arena.
I tried to grind off the aluminum part of the alternator to shear it off the
bolt, but there is not enough room to work plus my grinder uses up the air
before the compressor can put it back in the tank.
I did remove one bolt from the bracket where it mounts to the block, but the
through bolt blocks the removal of the second bolt - a disappointing design
by honda engineering.
any other ideas?
"Rocky" <jcadellano.spam@optonline.net> wrote in message
news:5xWze.9019$js.7744@fe10.lga...
>lower mounting of the alternator - 94 civic lx. I can't even move the alt
>by hand, so I have been using a prybar and large sledge hammer - then it
>moves, but won't free up enough to release the through bolt.
> when it will get splashed. It also would have made more sense to use a
Old Jul 10, 2005 | 09:16 PM
SoCalMike
Guest
Posts: n/a
Rocky wrote:
> any other ideas?
electric angle grinder, or sawzall? harbor freight sells cheap versions
Old Jul 10, 2005 | 09:58 PM
Rocky
Guest
Posts: n/a
sawzall - excellent idea - I'll have to get a metal cutting blade.
I test drove the car tonight - battery has a full charge - car ran good, but
I am concerned about white steam from exhaust - I'll have garage do a
compression test this week.
"SoCalMike" <mikein562athotmail@hotmail.com> wrote in message
news:X7-dnX0R48ztOEzfRVn-qA@comcast.com...
> Rocky wrote:
>> any other ideas?
Old Jul 16, 2005 | 11:13 PM
Rocky
Guest
Posts: n/a
I ran out of time to work on this and I asked the gas station torch off the
bracket. I had bought a replacement brack at the local Honda dealer -
$37.00 and they got it withing 24hrs. I had them order a new bolt and nut
too.
news:_ZjAe.153939$t07.4712@fe12.lga...
> but I am concerned about white steam from exhaust - I'll have garage do a
>> Rocky wrote:
>>> any other ideas?
Abeness
Guest
Posts: n/a
> too.
Sometimes you just gotta cut to the chase. Banging my head against a
stubborn bolt is not on my short list of things to spend my time on!
greenmonster2420
Nov 11, 2016 02:54 PM
deevergote
Dec 4, 2015 07:52 AM
running
Oct 26, 2012 12:20 PM
CuTeBoi
Feb 19, 2008 10:23 PM
Rocky
Jun 6, 2005 03:11 PM
