Window won't roll up shut. `92 Accord Honda
The left-rear window will not roll up all the way, leaving 1" gap.
It won't go up even when gripping on the glass and pulling on it. What should I look at to get the window to go up? Thanks |
Re: Window won't roll up shut. `92 Accord Honda
When that happened on my '90, the window actuator mechanism was
broken. Specifically, it is a metal frame with some plastic guides that control a cable driven by a little motor. One of the pieces of plastic was broken. caused the cable to not bring the window all the way up. Had to replace the whole actuator because the plastic piece was not a service item, new or used. Burns me up that the service price is controlled by a ten cent plastic part. It is not hard to take off the door panel to check it. By the way, when the second one broke, I didn't want to spend the money to fix it so I took of the interior panel, blocked the window closed and pulled the fuse on the window circuit for that window. On Tue, 12 Jul 2005 23:35:41 GMT, "Sam Nickaby" <Sam@none.com> wrote: >The left-rear window will not roll up all the way, leaving 1" gap. >It won't go up even when gripping on the glass and pulling on it. >What should I look at to get the window to go up? > >Thanks > > > > > > > |
| All times are GMT -4. The time now is 06:38 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
