Frozen and/or broken brake bleed valves.
Anyone have any advice on how to free frozen (rusted)
bleed valves. And if they brake, what is the easist, and cheapest fix. I could always replace the caliper/wheel cylinder, but that gets pricy, and 99 times out of a 100 you will have to replace the hard line. A coworkers daughter faces this problem. 19 year old starting college in 3 weeks and her money situation is tight. The brakes work, no squeal, but the peddle is mushy. She hasn't had any brake work done in the 3 years she has owned the car. Yea I know she reaps what she sows, but she is a nice, and otherwise responsable kid. I am up to changing the fluid and bleeding the brakes, but the valves scare me. Terry |
Re: Frozen and/or broken brake bleed valves.
Thought i would have that problem too but the bleeders cracked loose on a 17
year old Honda. <r2000swler@hotmail.com> wrote in message news:1123616492.477753.131430@z14g2000cwz.googlegr oups.com... > Anyone have any advice on how to free frozen (rusted) > bleed valves. > And if they brake, what is the easist, and cheapest > fix. I could always replace the caliper/wheel cylinder, > but that gets pricy, and 99 times out of a 100 you will > have to replace the hard line. > > A coworkers daughter faces this problem. 19 year old > starting college in 3 weeks and her money situation > is tight. > > The brakes work, no squeal, but the peddle is mushy. > She hasn't had any brake work done in the 3 years she > has owned the car. > > Yea I know she reaps what she sows, but she is a nice, > and otherwise responsable kid. I am up to changing the > fluid and bleeding the brakes, but the valves scare me. > > Terry > |
Try some PB plaster or other such penetrating lubricant. Spray it on
and let it sit for half an hour, try to loosen it, repeat if necessary. I used PB blaster to get off the lower exhaust manifold bolts on a 15 year-old toyota pickup... if it'll do that it should get your bleeder valves loose. |
r2000swler@hotmail.com wrote:
> Yea I know she reaps what she sows, but she is a nice, > and otherwise responsable kid. I am up to changing the > fluid and bleeding the brakes, but the valves scare me. gentle tapping on it to loosen the rust, then remove. if it breaks? id get an ezy-out tap and some new bleeder screws. its kinda a reverse-thread drillbit thingie that bites the metal and helps it unscrew. |
