94 civic - wouldn't start til turned steering wheel
ran fine on the way to work.
at lunch time, crank, but didn't even come close to catching. not flooded when I turned the steering wheel, then it started any suggestions what to look for? 176,000 us miles, 5 speed. |
Re: 94 civic - wouldn't start til turned steering wheel
Rocky wrote:
> ran fine on the way to work. > at lunch time, crank, but didn't even come close to catching. > not flooded > when I turned the steering wheel, then it started > any suggestions what to look for? > 176,000 us miles, 5 speed. > > tegger.com. main relay. |
Rocky wrote:
> > ran fine on the way to work. > at lunch time, crank, but didn't even come close to catching. > not flooded > when I turned the steering wheel, then it started > any suggestions what to look for? > 176,000 us miles, 5 speed. ============================ Car warmed up inside while sitting. Smacking the dash with the key in position II would have worked the same too. Replace or resolder the Main relay. 'Curly' |
Rocky wrote:
> ran fine on the way to work. > at lunch time, crank, but didn't even come close to catching. > not flooded > when I turned the steering wheel, then it started > any suggestions what to look for? > 176,000 us miles, 5 speed. The other suggestion made (main relay) is perfectly valid but it could also be the ignition switch. Since it started when you turned the wheel, perhaps you jiggled something that is making intermittent contact. I'd make sure that all connections to it are tight. Is it repeatable? Remco |
| All times are GMT -4. The time now is 05:09 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
