1992 CIVIC
NEED HELP SETTING TIMING
Re: 1992 CIVIC
"OLDGIRLPAPPAS92" <bgpappas68@aol.com> wrote in
news:418de6d928984dd57f5a651682d2d82b@localhost.ta lkaboutautos.com: > NEED HELP SETTING TIMING > > Don't shout. Turn off CAPS LOCK key. ------ Engine must be full-warm. All acessories off. 1) Jump grey 2-pin connector behind top of passenger kick panel (use paper clip). 2) Hook up timing light. 3) Loosen the lower two distributor bolts, but don't loosen the top one yet. 4) Start engine. Check timing. If adjustment needed, 5) Loosen top dist bolt. Turn distributor so mark on timing belt cover is in the MIDDLE of the group of three on the crank pulley. 6) Tighten top distributor bolt to lock timing in place. 7) Turn off engine. Remove paper clip and timing light. 8) Do up other two distributor bolts. -- TeGGeR® The Unofficial Honda/Acura FAQ www.tegger.com/hondafaq/ |
