CRV Auto Shift Lever Question...
Hello all -
I'm considering the Honda CRV (either new or late-model used), but have a question about its oddly-mounted shift lever (I will be shopping for an automatic transmission). Does it operate like a standard steering-column mounted shifter (which you generally have to "depress", move to the next position, then "release" to lock it in place... -or- Does it work like most floor-mounted auto shift levers, which can be freely moved between the "Drive" and "Neutral" positions? In other words, if you're driving along, coming to a stop, and you want to go from "Drive" to "Neutral", can you just nudge it into neutral (and back to drive) with a simple "push", rather than a "depress/move/lock" movement? Believe it or not, that's a "car breaker" for me. If it doesn't work like a floor-mounted lever, I'm not interested in the vehicle, and will shop for something else that _does_ have a standard floor-mount auto shifter. Thanks, - John |
Re: CRV Auto Shift Lever Question...
It works a bit different. You don't press any buttons to move it, just press
the brake pedal and then shift. It moves freely between neutral and drive. You have to nudge it a little bit to move it from Park. "John Albert" <j.albert@snet.net> wrote in message news:434ECA47.D76CCB83@snet.net... > Hello all - > > I'm considering the Honda CRV (either new or late-model used), but have a > question about its oddly-mounted shift lever (I will be shopping for an > automatic transmission). > > Does it operate like a standard steering-column mounted shifter (which you > generally have to "depress", move to the next position, then "release" to > lock > it in place... > -or- > Does it work like most floor-mounted auto shift levers, which can be > freely > moved between the "Drive" and "Neutral" positions? > > In other words, if you're driving along, coming to a stop, and you want to > go > from "Drive" to "Neutral", can you just nudge it into neutral (and back to > drive) with a simple "push", rather than a "depress/move/lock" movement? > > Believe it or not, that's a "car breaker" for me. If it doesn't work like > a > floor-mounted lever, I'm not interested in the vehicle, and will shop for > something else that _does_ have a standard floor-mount auto shifter. > > Thanks, > - John |
