Prius c
http://i1104.photobucket.com/albums/h338/phenoyz/1.jpg
would you trade it for this to get that mpg? |
it looks like what the CRZ should have been
Eff no... thats just... no
Sure, i'd rock that car, but how would I get into the boot
Short answer? No.
Long answer? NOOOOOOOOOO. ;D |
Looks good. But I don't like to worry about the life of the batteries and the cost of their replacement. Fit's engine is perfect, if a bit too big for my taste. I would really like a 1 liter powerplant... or the diesel.
Small displacement 3 cyl commonrail turbodiesel-electric is what I want to see.
Edit: In something that doesn't weigh two tons. With the motors mounted in-board to reduce unsprung mass. |
I heard the 3 cylinders are not commonly used because of them being inherently unbalanced and balancing them with heavy crank counterweights defies any benefits of of 3 cylinders vs 4.
Originally Posted by john21031
(Post 1003437)
:) I4 motors often have to use "silent shafts" weighted shafts that spins 180* out of phase at twice crank speed to reduce the associated secondary harmonics. Usually this is on larger than 1.8L. As far as NVH is concerned, its a diesel, few consumers would be able to tell the difference. And since the diesel will run constant speed in a diesel electric setup you can use the softest conceivable mounts because it is connected to a generator head and not the drivelines. Heavy counterweights are not a huge concern either because there is typically a damper on the timing case side and a flywheel on the bell housing side of most motors that weigh a ton anyways. |
The FoMoCo has talk of a turbo 3 cyl. gas fiesta coming out in 2013.
When this product is available...supposedly in about a year, I'll be interested. A Honda Fit "like" vehicle that get's 60+ mpg? With gas prices rising, and only likely to rise over the next 5 years...what's NOT to like?
This however, I believe is a picture of the prototype, concept. Recent heavily masked spy shots suggest the vehicle will be much more conservative in appearance, looking something like a Prius and a Honda Fit morphed. |
(Post 1003441)
Kinda the other way around actually.
I4 motors often have to use "silent shafts" weighted shafts that spins 180* out of phase at twice crank speed to reduce the associated secondary harmonics. Usually this is on larger than 1.8L. As far as NVH is concerned, its a diesel, few consumers would be able to tell the difference. And since the diesel will run constant speed in a diesel electric setup you can use the softest conceivable mounts because it is connected to a generator head and not the drivelines. Heavy counterweights are not a huge concern either because there is typically a damper on the timing case side and a flywheel on the bell housing side of most motors that weigh a ton anyways. Engines with more than two cylinders with characteristic balance problems include:
Also check here: http://www.autozine.org/technical_sc...ne/smooth1.htm it describes the balancing challenges for 3 cylinder engines. |
I rather take the Prius minivan they have in Japan.
(Post 1003487)
It seems the 3 cylinder is always described as having inherent balance problems.
Also check here: AutoZine Technical School - Engine it describes the balancing challenges for 3 cylinder engines. No widely used engine configuration is perfectly balanced for secondary excitation. Every engine has secondary harmonics. The closest to "inherently balanced" would be a I6/H6 or V12. If 3 cylinders were so bad why would Daimler Benz use them in the Smart? Or VW with the Polo? Or any of the other 3 cylinder cars throughout history? And again: in a diesel electric you can put the 3cyl on some super soft or even active engine mounts because it is attached to a generator head and not a transmission with a physical mechanic link to the ground. Aside from startup, the engine should be running at a constant speed anyways so you can pick an RPM point that doesn't produce undesirable NVH characteristics. |
No , but I'd trade my current Fit for this Hybrid one:
http://www.caranddriver.com/var/ezfl...ticlesmall.jpg |
