Old Jul 1, 2016 | 09:02 PM
  #8521
Originally Posted by Hootie
The Honda Access ambient light kit is one of the few dress up/non-functional things I've always wanted on my Fit.
Can you take pics as your do your install? I'm curious if it would be plug and play or would require a little bit of wiring work.
From what I read, I heard it was plug and play.
Old Jul 1, 2016 | 09:52 PM
  #8522
Hootie's Avatar
Interesting... I must investigate.
Old Jul 1, 2016 | 09:59 PM
  #8523
Hootie's Avatar
Old but new since I haven't updated in forever and a half. Been streeting my new autocross wheelset for about a month now. 15x9 Advanti Storm S1s and 245/40R15 Maxxis Victra VR-1s... Minimal rubbing with a 3mm spacer thanks to my spring rate.
205/50R15 vs 245/40R15
Attached Thumbnails What did you do to the GD Fit today?-80-13435491_10153809072293983_7266166790170839555_n_a009ea00022bf3706ea24d2173045809402924f6.jpg   What did you do to the GD Fit today?-80-13509101_10153832514303983_1040177112854899588_n_bd0387f7de9ac524f699e789adb2161597bfab23.jpg
Old Jul 2, 2016 | 02:49 PM
  #8524
apexanimal's Avatar
killer... those tires have the miata crew all worked up...
how do you like them?
Old Jul 2, 2016 | 08:34 PM
  #8525
fittenmittens's Avatar
Installed GE Injectors into my GD (~250k injectors were struggling). Noted increased injector noise, but the car smoothed out and lost its misfire.
Did my 0% oil life oil change with 0w20 Mobil 1 synthetic from those rebate deals that I got for $10 shipped. Using Bosch premium oil filter for now.
Trying a "magnetic" drain plug for this interval, will see what gets stuck to it for the next change...
Old Jul 3, 2016 | 11:18 AM
  #8526
mnapuran's Avatar
Ugh.... cars in the shop. A/C has been having issues, and after 2 charge checks this past week, we finally found the leak - It's the Evaporator core in the dash.
Another issue... tried 3 different replacements, and all 3 are wrong in that they have connections that are not correct, or the unit doesn't fit properly in the tray that it mounts in. Hate to have to go to Honda to get replacement
Old Jul 3, 2016 | 10:27 PM
  #8527
mangosmoody's Avatar
Finished up a diy project for my daily the fit, painted my panels black and pillars, to convert to black. Also painted my wheels.
Attached Thumbnails What did you do to the GD Fit today?-80-20160703_201505_a2e3e092e533cf427406aa452ccf5c4c55f56873.jpg   What did you do to the GD Fit today?-80-20160703_201522_c88d23622a677bf216a1d1e2f7a976418c655e3e.jpg   What did you do to the GD Fit today?-80-20160702_152021_d37c81d59553951ab9c20c8ce7f06ad1d87e9295.jpg   What did you do to the GD Fit today?-80-20160702_150300_b49ab54885bd4b7f42d920280f147c7decb9efe1.jpg   What did you do to the GD Fit today?-80-20160702_155453_929aa507e7c275296f37e444109a82b43986ccba.jpg
What did you do to the GD Fit today?-80-20160703_104818_31764561b3b0190bd095f01d8e543aa986f286b1.jpg   What did you do to the GD Fit today?-80-20160703_141002_0a7757f658eca9c05aa595477ab55fdb802e164d.jpg
Old Jul 5, 2016 | 11:54 PM
  #8528
g95pteg's Avatar
Who makes these rims and what kind of paint did you use?
Old Jul 6, 2016 | 11:53 AM
  #8529
Super Road race, i used rustoleum white primar, vht gloss white high heat engine ceramic paint, and vht wheel gloss clear coat.
Old Jul 6, 2016 | 06:10 PM
  #8530
dwtaylorpdx's Avatar
FWIW.. POR-15 makes a NICE white and some specialty coatings for hot bits like calipers, Dont be afraid of brushing it on its an amazing leveling paint..
Old Jul 6, 2016 | 09:53 PM
  #8531
g95pteg's Avatar
awesome thanks! they look great! want them on my ge
Old Jul 7, 2016 | 10:14 AM
  #8532
thanks you can find on ebay, they used to have a web site but looks like its gone so not sure if they went out of business. Youre going to need hub rings and they are not common 64.1 to 56.1
Old Jul 11, 2016 | 06:21 AM
  #8533
DWils's Avatar
I saw IATs at over 150F/66C this week. Not bad considering that was only a few degrees above ambient temps outside. Thankfully the Fit hasn't blown up yet, caught fire, or melted. I guess a steady healthy diet of rice makes Fit strong like bull. My fuel economy has gone down a bit (1-2mpg) over the last month or so due to me actually using the air conditioning now that the Fit makes enough power to run it.
Old Jul 11, 2016 | 09:05 AM
  #8534
DanMarino's Avatar
Old Jul 11, 2016 | 10:02 PM
  #8535
Originally Posted by DanMarino
Nice good stuff I was thinking of the rear bar and wasn't sure but looks sturdy
Old Jul 12, 2016 | 09:05 AM
  #8536
Jake Fowler's Avatar
I Forever Blacked the windshield cowl over the weekend. Pretty useless since I broke the two hinge covers as they came off and it's already faded again. They're only 5 dollars from Honda so I'm not too worried about them, I'll get those, pull it off and run a couple more coats over it, and replace the covers.
Old Jul 12, 2016 | 09:28 PM
  #8537
So after much consideration i kept going back and foth about the JDM arm rest and i just couldnt justify for an arm rest paying the buku money people want. id rather spend that money on performance parts or something worth wild to me. So instead i tried out the whole bolt on arm rest and see how it works, and i like it. alot of you might flame on me for doing so but i dont care. I just wanted to share.
Front part
REAR view has a pop out cup holder as well
WHERE is bolts in
and with the tray, also has a coin holder as you can see.
Attached Thumbnails What did you do to the GD Fit today?-80-20160712_210311_687a0f15721f60694308e639eb325dde45c5dda4.jpg   What did you do to the GD Fit today?-80-20160712_210330_d0bc8f9034e6544b741253dd22352a48b66ec944.jpg   What did you do to the GD Fit today?-80-20160712_210620_43c3cc79ca16ba12beb007eb1bc820f8f546ac46.jpg   What did you do to the GD Fit today?-80-20160712_210650_a3c98cd7e5df2589c86100876844b964b9e45005.jpg
Old Jul 13, 2016 | 11:37 AM
  #8538
Jared592's Avatar
I made the same decision. Totally worth it for the money.
Old Jul 19, 2016 | 07:39 PM
  #8539
Added a JDM visor with mirror and card holder
Old Jul 20, 2016 | 09:53 AM
  #8540
Got some JDM rear head rests and Honda Access blue footwell lights.
