HELP!!!!! Just bought a 2011 Honda fit sport and need help
Hello I am new to this site I have recently bought a 2011 Honda fit sport 1 owner car in pretty good shape. I have a million questions lol. How can I take out the stock air filter box there is a sensor on it? Also what's the cheapest way to get a better suspension rides like crap? And does anyone know the size difference between the 07 and 11 passenger front door?? And does anyone know where to get a whole new carpet that's meant/molded for the 2011 fit I have looked everywhere and can't find NOTHING out there. Thanks you guys/gals I really would appreciate the help !!
Loads of questions is right, haha. If you're trying to put a door from an 07' onto your 11' Fit, it will not fit, totally different chassis and body shapes. New carpet you may have to order from Honda or try your luck with a salvage yard and do a proper shampoo/deep clean. A better suspension will cost money, what exactly seems to be wrong with it? Keep in mind it is a small, inexpensive car, so it will ride like one. There are options, however. The old adage ks " cheap work isn't good, good work isn't cheap" holds true with parts as well. Why do you want to remove the factory air box? Most quality aftermarket intake systems will have a place to relocate that sensor , so you don't get check engine light codes. Good luck! Welcome to the forums!
if youre not...then here you go
ok sorry heres my serious answer.
...suspension and airbox, you can use any honda parts..just pick a car u like and swap it onto your fit. same with the doors and carpet actually. Hondas are pretty much legos. mix and match and build your dream car!
nietofit07
Off Topic Discussion
07-27-2014 12:28 PM
