Anyone need fenders rolled??
im just tryin to earn a few extra dollars. The fit is about as easy as it gets when it comes to rolling. interested shoot me a pm or text/call me 713-391-7747
I will probably not check this thread often, so pm or phone contact would be the best!
bumps, bumps, bumps,
When I am able to head down that way I'll give you a call.... My wife will give me hell if she opens my address book and sees a phone listing for Chunky Lover 8200...
did you get my PM chunky? I sent you a PM for fender rolling. Please contact me 713-444-2654 with how much you charge.
Can someone tell me what fender rolling actually is...sounds like fun :p
rolling your fenders just adds clearance in the fender well for bigger wheels.
I'll be installing coil overs and 205-50-15s on 7" wheels with 41mm offset and have a set of 205-40-16s on 7" wheels with 38mm offset... I need to also get new inner fender liners before I need to get with you...
(Post 1047511)
Originally Posted by chunkylover8200
(Post 1047860)
rolling the fronts requires the fender liner to be cut, because they wont have anywhere to mount onto the fender. if you dont cut the liner, they will roll on tight hard turns.
(Post 1047887)
The ones I have on it now popped loose in front at high speed and hit the tires... I believe that I read somewhere that the liners have to be cut and some how glued in place to still be useful.. Maybe I can get some sheet metal and cut it to pop be riveted into place over the part that is worn through....:wavey:
(Post 1047887)
