Anyone throw any codes since winter's shown up?
Old Nov 27, 2006 | 10:56 AM
MarkB's Avatar
I threw one on the weekend. Not sure what it is yet. Nothing major. car is running fine. It was plus 12 the day before and minus 12 in the morning. I wonder if that was the factor? I'll know what it is shortly.
Old Nov 27, 2006 | 11:53 AM
startroops's Avatar
No codes yet, but Vancouver winter ain't that bad at all compared to the Prairies.
Old Nov 27, 2006 | 12:03 PM
MarkB's Avatar
True that. We've been above normal so far. Plus 12 at the end of Nov is unheard of.
Old Nov 27, 2006 | 01:04 PM
pokems23's Avatar
June 2007 3rd Place Fit of the Month Winner
Nothing yet, but had tough time going on steep snowy hills with my Manual. SLIDING!!!!!
Old Nov 27, 2006 | 04:03 PM
MarkB's Avatar
ECT and IAT. Conflict with the 2 regarding temps. I had it plugged in on the weekend .( -15) He said I should wait until at least -20. Apparenly this happens with Integra's as well. ( Dealer ship guy said this)
Old Nov 27, 2006 | 07:52 PM
willmax11's Avatar
Define "plugged in on the weekend".
I've been plugging in my block heater for only a 1/2 hour for over a month.
(Only on the coldest mornings.)
Just enough to cut down the wait time for the cold light to go out and the idle to come down to 1,000 rpm.
No sign of any problems.
Old Nov 28, 2006 | 12:03 AM
kps's Avatar
kps
Honda Fit Forums Moderator
So have I, almost every morning on a timer, including days like today (+12°).
Old Nov 28, 2006 | 08:17 AM
MarkB's Avatar
I plugged it in around 11pm and unplugged it around 7am.
Old Nov 28, 2006 | 09:21 AM
kps's Avatar
kps
That sounds odd to me; you have the same 'conflict' whenever you start the car warm. Do you know the actual trouble code?
Old Nov 28, 2006 | 03:11 PM
MarkB's Avatar
Not the actual code but it threw 2 codes. So the Tech figures there was a conflict. He's seen this kind of error before, But not on Fit's. This was actually his first scan job on a fit.
Old Feb 17, 2007 | 08:39 AM
MarkB's Avatar
UPDATE:
Apparently there is a reflash for the fits already for a fix.
Old Feb 17, 2007 | 03:32 PM
Dañiel's Avatar
Hey, after the last cold spell in Winnipeg I'm surprised any cars are still running.
Old Feb 17, 2007 | 08:27 PM
HavingafitinOntario's Avatar
No Trouble North of Barrie this Winter
My Fit has performed excellent this winter season! On the coldest mornings it cranked up and started with ease.
Looking forward to the Spring to add some modifications to my Fit.
Old Feb 18, 2007 | 10:28 AM
MarkB's Avatar
Never any problems starting in the morning. The conflict came from when it was plugged in. Anything warmer than -15 ( like mornings of -12 - -15) I would get a check engine light. Anything colder was Fine. It has something to do with the coolant temp sensor reading incorrecly during start up when it's plugged in at those temps ( above - 15)
Old Feb 19, 2007 | 12:48 PM
MarkB's Avatar
Correction. The reflash was only for the air bag recall. Kinda sucks. I'll have to clear the codes until they find a fix i guess.
Gouuuulet.
Old Feb 22, 2007 | 08:50 AM
b17gsr's Avatar
I'm having the odd problem starting it when cold. It cranks fine, but seems like there's no gas. If I turn off the Fit and start it again, it fires up. Seems like I'm having issues with the fuel pump and the check valve (loosing fuel pressure in the line when not in use).
NMPastor
Sep 15, 2011 01:23 AM
g33s0n6656
Jan 9, 2009 11:00 AM
willmax11
Mar 31, 2007 10:38 PM
willmax11
Dec 1, 2006 11:30 PM
FitSam
Ohio Community
Nov 10, 2006 02:46 PM
