1994 Honda Civic- Ignition lock
Old May 10, 2005 | 11:42 AM
dtrejo
Guest
Posts: n/a
Someone tried to steal my sons Honda and destroyed the ignition key hole.
The steering wheel is in the LOCKED position. We have plugged in a new
ignition and the car does start, its that the steering wheel is still
locked. How do I unlock it? Please help. THANKS
Old May 15, 2005 | 07:30 PM
Tim Zimmer
Guest
Posts: n/a
Re: 1994 Honda Civic- Ignition lock
Try to unlock the steering wheel with the cylinder removed. Use a Phillips or
flathead screw driver. If it won't unlock then the mechanism is either broken
or a shattered material has jammed the ignition column assembly.
jim beam
Guest
Posts: n/a
if that's the case, the o.p. needs to be very careful when they free up
the mechanism. if the shaft has been scored & damaged, it can in time
fatigue. potentially fatal. that's how ayrton senna died. best policy
if damage is evident is to go to a junk yard & get a replacement
steering shaft assembly. fairly quick & simple to replace. hardest
thing is removing the steering wheel! check the helm manual for proceedure.
clavocanela
Feb 3, 2018 01:51 AM
FitRaptor
Aug 30, 2016 07:24 AM
FitfulKenny
Dec 4, 2015 09:45 PM
Bronxborn
Jun 9, 2015 10:38 AM
pr1970
Nov 17, 2012 07:52 AM
