Transmission Oil Change
Old May 25, 2010 | 11:59 PM
ACMierzeje's Avatar
I would like to know the torque specifications for the manual transmission oil drain and refill plugs on the 2009 Fit Base. Thank you.
Old May 26, 2010 | 12:22 AM
Koi's Avatar
Koi
On the GD3 it is 29 lb-ft for drain, 33 lb-ft for fill.. don't know specific for 2009 though
Old Jun 12, 2010 | 07:33 PM
Krimson_Cardnal's Avatar
Same on the 09-10.
Old Feb 4, 2011 | 03:13 AM
mole177's Avatar
I'm going to bump this...
what mileage should I change this out at? Can i refill with mobil 1?
I assume the process is take out drain, take out fill, once trans oil stops draining, replace drain plug, pour in trans oil through fill port and keep going till it levels off?
Old Feb 4, 2011 | 03:17 AM
TunaDaMan's Avatar
The process is to take out the fill bolt first then the drain bolt, because if you manage to take off the drain bolt and not the fill bolt you sir are screwed...
Then put the drain bolt back in, fill it up until it just starts to drain out of the fill hole, then you pt the fill bolt back in and you are done
Old Feb 4, 2011 | 11:56 PM
mole177's Avatar
cool.
preference and estimate amt of fluid?
Old Mar 21, 2012 | 07:39 PM
gruenes's Avatar
Can anyone post a picture showing where the drain plug on the automatic transmission is located for a 2009? The service manual is worthless in this regard.
Old Mar 21, 2012 | 07:46 PM
Funkster's Avatar
Should be marked in blue and be a 3/8" square input I believe.
Old Mar 21, 2012 | 07:49 PM
gruenes's Avatar
ahhh found it, thanks for the description. Very easy to get to actually. thanks.
Old Mar 21, 2012 | 08:25 PM
Funkster's Avatar
My pleasure.
Old Mar 21, 2012 | 09:21 PM
spreadhead's Avatar
You can fill the transmission through the dipstick hole. It's easier than the fill hole. I think a drain and fill is about 2.5 quarts.
Old Mar 24, 2012 | 07:28 PM
climhazzard's Avatar
There is no dipstick on the manual trans, only automatics. I don't know the exact capacity off the top of my head, but it's definitely less than 2 qts. I also suggest Honda's own MTF fluid.
Old Mar 24, 2012 | 07:40 PM
Funkster's Avatar
Manual says 1.6 Qts. However, just fill it until it runs out of the fill hole and then let it dribble to a stop. Make sure the car is level.
Old Mar 24, 2012 | 08:00 PM
gruenes's Avatar
automatic transmission oil change
It took 2.7 quarts exactly to refill after draining. I am wondering how many times doing a partial oil change will be ok. I assume there is some sort of filter inside that needs replacing
Old Mar 24, 2012 | 08:03 PM
Funkster's Avatar
Wait, for an AT or MT?
Old Mar 24, 2012 | 09:39 PM
Goobers's Avatar
I think he's talking about A/T, since I recall mention of "partial" drain/fill in other threads related to the A/T.
Old Mar 24, 2012 | 10:02 PM
Funkster's Avatar
Ya, I would have to assume the partial comes into play since you can't get all the fluid out on an AT. The torque converter likes to hold a lot of it.
Old Apr 14, 2012 | 04:33 PM
dovey's Avatar
every how many thousand miles should the transmission oil change? thanks
Old Apr 14, 2012 | 04:43 PM
Starks's Avatar
Owner's Manual says first transmission fluid change at 60k then every 30k after that. (Maintenance Minder #3)
Davethegoat
Dec 19, 2018 11:34 AM
Davethegoat
Dec 19, 2018 08:03 AM
moolman
Apr 3, 2012 01:20 PM
ccl088
Mar 8, 2009 03:03 PM
John Edwards
Oct 19, 2005 01:32 PM
