how to change license plate blub
Old Jun 22, 2006 | 03:22 PM
sy11580's Avatar
does any one know how to change the License Plate blub? I have no idea how to remove the plastic cover to change the blub!! I have one of the blub burn out!!!
Old Jun 23, 2006 | 05:26 PM
Wave's Avatar
you figure it out yet?
Old Jun 23, 2006 | 06:54 PM
uiskibum's Avatar
I would reccoment getting the downloadable repair manual if you don't plan on ordering one from Helms. For the time being I put this together from the downloadable manual.
changeLight.pdf
Cheers!
Old Jun 23, 2006 | 07:37 PM
gimme's Avatar
Master FitFreaker
check access through the rear hatch.
Old Jun 24, 2006 | 01:49 AM
sy11580's Avatar
No WAVE!!! I try to put, move it to right, move it to left still don't work!! the Plastic wrote down the arrow and it say"REMOVE" but really don't know how to hell move that crap!!!
sy11580's Avatar
changeLight.pdf
Cheers!
Thanl for your like that may too much work to do
Old Jun 26, 2006 | 08:28 PM
Hasafraker's Avatar
Thanks that's handy, I was thinking about putting red bulbs in there, but OMG you'd think the designers said "well... We've got 10 pallets of these little fasteners, the boss said use'm all up! I'm pretty sure we can use 30 of these things in the hatch!" I spose you could look at it like "it's damn sure not gonna come off accidentally"
Old Jul 2, 2006 | 08:57 AM
Wave's Avatar
I changed my license plate bulbs to LED's from www.superbrightleds.com
Hey anyone know where I can replacement clips? It would be the (2) clips that are listed as part B in the PDF link above. I broke them trying to get the cover off!
Old Jul 2, 2006 | 01:51 PM
sy11580's Avatar
Can u tell me?
Wave you changed it? How did u do that? tell me tell me!!!
Old Jul 2, 2006 | 01:53 PM
Wave's Avatar
click on the link below and follow the directions!
changeLight.pdf
Cheers!
Old Jul 4, 2006 | 09:30 AM
uiskibum's Avatar
you should be able to get those from Honda if they are just those ever annoying snap clips. Take the pieces into a parts counter and see what they can come up with.
Old Jul 22, 2006 | 05:53 AM
clk1022's Avatar
How do I remove the (10) chips in part C after remove the 2 clips in part B? I dont see any chips there. please help. thanks.
Old Jul 22, 2006 | 02:21 PM
clk1022's Avatar
Got it~~Thanks for the info. it's very helpful!
Old Sep 14, 2006 | 09:01 PM
alclssus2020's Avatar
License Plate bulb replacement?
http://cgi.ebay.com/161-168-194-2825...QQcmdZViewItem
I need to replace rear license plate bulb with LED bulbs. On the service manual, the bulb # is 168. Would this fit?
Old Sep 15, 2006 | 02:50 AM
koolkevin1107's Avatar
yeah a 168 bulb is the same as a 194 bulb. The 194 is more commonly used and is known as a wedge bulb. That guy is sellin em waaaay too expensive. I buy all my bulbs from www.autolumination.com and i have never had a problem with them. Those led's will fit but its really not necessary and it won't give you more light then what you have b/c led's focus the beam in one direction and the rear hatch bulbs are facing towards the back, not down towards the licence plate. Just get some 194 hyper whites and u'll b set. That's what i did. =]
Old Oct 28, 2006 | 05:16 PM
LiL Wee FIT's Avatar
Help with license plate bulbs replacement!
I am trying to replace the license plate bulbs, and it is a PAIN IN THE Arse!! I downloaded the Fit manual here, and it said to take apart the trunk trim panel to get to the bulbs. But there are like 10+ clips holding that stupid panel together! I tried to pry that panel open, but I was only sucessful in getting 2 of the clips on one of the sides.
I also tried to CAREFULLY pry the bulb cover from the outside, but had no luck.
Anyone tried to replace the license plate bulbs? How did you go about doing so?
-Sherman
Old Oct 28, 2006 | 08:50 PM
vividjazz's Avatar
Someone that Posts too much
Don't know wether our Honda Jazzes and those sold in the rest of Asia including Japan are enormously different but our 2 bulb holders just slide out to one side without taking apart anything. Then the bulb just clips in and the cover slides / clips back into place. The covers can be a bit stiff to move the 1st time.
The illustrated instructions are in the manual in our gloveboxes that came with the car. Easier than changing the headlight bulbs or even the parkers.
Old Oct 29, 2006 | 01:08 AM
Oh man.. thank you soo much vividjazz!
You were right! I don't have to use any tools at all! Just push the bulb covers towards the right side / passenger side (NA cars) and they'll come loose! Felt soo stupid after spending hours and hours trying to change it... Haha!
I was planning to put LED bulbs in.. but they were too big, so I just went with hyper white bulbs. In the meantime.. I'll wait for someone to come out with some super duper bright LEDs, while keeping them the same size.
Thank again!
Sherman
Old Oct 29, 2006 | 06:26 AM
vividjazz's Avatar
You might want to check out what these guys have
http://www.ledshoponline.com/automotive_leds.htm
Polarg B1 Hybrid made in Japan have LEDs which you can use for the number plate lights and parkers. I'm sure there are heaps of Polarg stockists in NA.
Old Dec 15, 2006 | 07:36 AM
Ings-net's Avatar
sorry, i don't understand wat is 168 and 194, is that call m4/t10?
