how to change license plate blub
Old Dec 15, 2006 | 10:12 AM
koolkevin1107's Avatar
i looked on google but i couldn't tell. here are some pix below to show u what a 168/194 bulb is. I checked out the polarg page and it says m-4 on the top but don't take my word for it. just take a look @ the pix.
Old Dec 15, 2006 | 10:27 AM
Wave's Avatar
Oh Snap!
Thanks you just cost me a bunch of $$$ on lightbulbs for my car!
Specifically (4) Eagle Eye II's in size 7440 for the rear tailights...
Old Jan 6, 2007 | 09:44 PM
sorrikim's Avatar
How to remove
Can someone tell me how to remove the license plate light bulb cover?
I says "remove" with right-arrow on the cover, but I was not able to remove it. Which way do I have to pull out after I push it to the right?
Thank you!!
Old Jan 6, 2007 | 11:33 PM
Jimmy101's Avatar
Remove the interior hatch cover.
then you will see the license plate lamps.
Squeeze both sides, and out they come.
Old Jan 8, 2007 | 11:23 PM
sorrikim's Avatar
how do i remove the interior hatch cover?
I think I don't understand the picture very well.
Old Jan 8, 2007 | 11:31 PM
j5ive's Avatar
this was near the top of page 2 in this lighting subforum:
Help with license plate bulbs replacement!
No need to remove interior hatch cover apparently.
Old Jul 30, 2007 | 05:37 PM
cojaro's Avatar
None of the links work anymore. This makes me sad...
:'-( <-- see, t3h sadness
Old Aug 12, 2007 | 02:25 PM
GeniuneFit's Avatar
Originally Posted by Ings-net
sorry, i don't understand wat is 168 and 194, is that call m4/t10?
Polarg has their own way to number their bulbs. Polarg's small M4 wedge is 168/194.
Old Nov 15, 2007 | 04:34 PM
diedwater's Avatar
I wanna switch my light to blue, but I couldn't find one that fits, has anyone done this? if so what bulb did you use?
Old Nov 15, 2007 | 05:13 PM
the bulb size is 194. I do NOT RECOMMEND getting glass bulbs that are painted because i had some lying around from my old car and installed them on my fit. A week later one was out and when i check the housings, the glass broke and the housings were melted!!! i had 2 order TWO new license plate housings and covers ($10 each side) so now i switched them to LED'S. Here is where i get all my led's:
www.autolumination.com Tail Light Brake Light Turn Signal LED Bulbs
this is the direct link to where u can find the 194 bulbs that i used.
194 168 W5W 2825 Map Led Parking Signal Marker Bulbs
Scroll down until u see where it says:
194 Signal/Marker Bulbs.
(Inverted Lenses Emit Light out the sides of the bulb)
U need an inverted bulb (that shoots light from the side rather then a traditional LED that focuses light out the tip of the nose) because the led doesn't face directly down at the license plate to illuminate it enough. The side emmiting led's work the best and are very bright.
Old Nov 15, 2007 | 06:28 PM
azncarbos's Avatar
can anyone post the link to replace the bulb. thanks
Old Dec 1, 2007 | 01:13 PM
  #32
billmus86's Avatar
My Lips Bigger!
you just slide the lens in the direction of the arrrow and pull straight out at the same time-- its a tight fit but really easy to get
i recommend superbrightleds.com and go with the five led 168s i got cool white- also avail in warm --- just have your remote handy and press the unlock button - this will blink the lights so you can see if the work (polarized so flip em if they dont) that way you dont have to run all the way around to the front and back and then back to turn off
Old Feb 13, 2008 | 04:30 PM
  #33
UN_FIT's Avatar
bump.. so from what i can tell we can just go straight through the plastic pieces in the trunk itself to remove it?
Old Feb 13, 2008 | 05:58 PM
  #34
azncarbos's Avatar
Yes...just be really carefully....I'll show to you this weekend
Old Feb 14, 2008 | 12:29 AM
  #35
diedwater's Avatar
yuuup easier then cake walk
Old Feb 14, 2008 | 01:53 AM
  #36
zer0sk8ordie's Avatar
haha yah i changed mine and broke the slider cover thing. then i was like oh i dont wanna break the second one. haha sure enough i broke them both! hahaha they are so fragile
Old Feb 14, 2008 | 02:16 AM
  #37
doctordoom's Avatar
Supervillain
something to note: the covers don't really slide. they're stuck in there the way a AA battery is stuck in a gameboy, or a AAA battery in a gameboy pocket. hope that makes sense, so if anybody tries in the future you'll be less likely to break the cover.
Old Mar 29, 2008 | 12:00 AM
  #38
Special's Avatar
nice analogy! Rep'd! ...though i regret not looking this up before i bought my leds...
Old Apr 19, 2008 | 01:12 AM
  #39
Special's Avatar
Update: Buddy was buying LEDs so i went in on the deal to save on shipping. Picked up the WLED-WHP6 LED from superbrightleds.com in Cool White. Overall I am happy with the bulbs, as i was scared that they would turn out with too much of a blue-hue but they emit a very white tone. Though the bulbs are a bit not as bright, the light distribution is very good.
on with the pics
Stock:
L (stockt) R (LED)
LEDs In! (Note: they looks more blue in the pics)
Old May 18, 2008 | 09:31 PM
  #40
Jujutzin's Avatar
I did the same thing!! Do I have to go the dealer to buy new ones or can I order some online? Does anyone have a part number?
