HELP! 99 Honda Accord dashboard backlight is out!
Old May 28, 2005 | 04:41 PM
dexue
Guest
Posts: n/a
Hi everyone,
My 99 Honda Accord dashboard backlight is out!
I tried to adjust the dimmer switch, I turned both directions, no
light.
I checked the fuse boxes. All fuses are OK.
Do you think this is caused by a bad dimmer switch? or a loosed wire?
If a bad dimmer switch is the problem, how do I fix it?
Thanks in advance,
James
duckbill
Guest
Posts: n/a
Re: HELP! 99 Honda Accord dashboard backlight is out!
Were the lights getting dimmer over time or did they just go out without a
flicker? I would check the applicable fuse again and replace it with a
neighboring, like fuse, just to be sure. Also, you're aware there are
fuses and relays under the hood as well as under the dash, right? Good
luck.
Old Jun 3, 2005 | 01:06 AM
dexue
Guest
Posts: n/a
I double checked and found a blown fuse. I replaced it with a same 15
amp fuse, but as soon as I turned on the head light switch, it blew
out. I am sure it must be short circuit somewhere. According to the
label, the fuse is for license light and some small lights.
Thor667
Jul 10, 2021 05:39 AM
Mister Coffee
Apr 3, 2015 10:35 AM
Fat Ping Cat
Jul 5, 2008 12:34 AM
W
Sep 29, 2005 12:30 PM
fredvig@comcast.net
Jul 12, 2005 03:30 PM
