15x7 35mm offset 195/55 or 205/50
Old Feb 17, 2007 | 08:54 PM
Bounty Hunter's Avatar
Will these work? Just curious because I might be purchasing this size for my '93 SE-R to AutoX on. Just thinking of other options if I decided to run them on my Fit.
Old Feb 18, 2007 | 11:58 PM
squareback's Avatar
I've not tried that size on a Fit, but I can tell you that a 15x7 with a 41mm offset clears fine with a 205/50 Falken Azenis, which tends to run wide. It's close, but it clears. I suspect you would have to roll fender lips with a 35mm offset.
There's someone here with a silver car and white 15x7 Kosei wheels, which I think have a 38mm offset. You might try to find out if there's any clearance issues with those.
Mike
Old Feb 19, 2007 | 01:41 AM
spoonek4's Avatar
Kosei K1 with 15x7 +45mm and 3mm spacer all around. I've installed camber bolt and this was before it went into the shop for alignment. About -1.8degree camber or so up front....no rubbing at all!
U can ask Ben @ A&J Racing for some advices coz I think he got some CE28N in 15x7 +35mm offset on his Fit.
mikeGe82012
May 28, 2017 12:11 AM
Muster
Jun 24, 2011 06:02 PM
billyb
May 15, 2010 01:55 PM
jonno86
Sep 20, 2009 08:31 PM
rvall004
May 20, 2008 04:08 AM
