Does fan should running all the time?
Old Jun 27, 2005 | 08:22 AM
mmdir2002@yahoo.co.uk
Guest
Posts: n/a
I noticed that my honda 89 civic the fan is not running
everytimes I've opened the hood and just looked at it.
The fan was not running. If my fan is not running, should my
temp gauge going up more I drive the car, but it doesn't. The temp
gauge shows the normal temp. Today I opened the hood when the temp
gauge is normal level, I started the car the fan was running on couple
of seconds, then it stop.
Is this normal? What possible problem I might have?
Does it has to do with theomostat?
Randolph
Guest
Posts: n/a
Re: Does fan should running all the time?
The fan is controlled by a thermo switch. It should not run all the
time. In hot weather it comes on more often, and it comes on more often
when you are driving slowly or at idle.
A very modest collection of Honda tech info can be found at:
http://www.geocities.com/ng_randolph
Pars
Guest
Posts: n/a
I think my engine fan is running a little too much. I wonder if it's a sign
that my radiator is starting to go bad?
Pars
98 Civic Hatch
Frank
Guest
Posts: n/a
If you gently "scratch" the radiator fins with your finger nails and that
they bend or fall off, your rad is bad and needs to be changed. Other signs
are a redish or greenish colors on the rad means a replacement is required
soon. But if it's like 35C outside, its normal for the fan to run every 1-2
minutes when idle.
"Pars" <sdaro(remove)@hotmail.com> wrote in message
news:l9OdnbsKLJQcRybfRVn-vA@rogers.com...
> sign
> Pars
> 98 Civic Hatch
hogwylde
Sep 29, 2011 02:44 PM
fitisbamf
Feb 21, 2011 11:56 PM
FELIXY69
25
May 21, 2010 04:35 AM
Gary
Oct 13, 2005 11:31 PM
Dr. Joel M. Hoffman
Jul 16, 2005 10:43 AM
