Offset on Civic HX wheels for base Fit?
Old Apr 10, 2007 | 04:19 PM
j5ive's Avatar
Hi there,
I'm posting this in the racing forum because I'm hoping more people here would know the specs on the HX wheel since I think it's one people use for AutoX often.
Anyways, I was trying to search for the specs for the base fit steelie wheels, and this was the only thing I could find was this Post from Mini-Fit stating that they are 14x5.5 et+45. This is correct?
My question is, what's the offset on the HX wheels? I know they are 14x5.5 as well. Basically, I want to know would they keep my Fit in H-Stock?
Thanks all.
Old Apr 10, 2007 | 09:10 PM
siccmonkey's Avatar
not sure of the offset but they will not fit without spacers in the front
Old Apr 11, 2007 | 03:41 AM
j5ive's Avatar
Siccmonkey, thanks for the reply. Now, is this based on your experience? If so, where was the issue with fitment in the front? Brake caliper/wheel spoke clearance?
The reason I want to ask is because I've heard conflicting info on the offset of HX wheels. But the highest offset I have heard of is +50.
Using that and the width of 5.5in, and running it through any wheel offset calculator, I can't see any clearance problem with the struts on the inside, nor the fenders on the outside.
Base: 14x5.5 et+45 ---> HX 14x5.5 ET+50
same width, so inner clearance reduced by 5mm, outer position reduced by 5mm
Sport: 15x6 et+55 ---> HX 14x5.5 ET+50
Inner clearance INCREASE by 11mm and outer position reduced by 1mm
So by the numbers the HX wheels SHOULD clear the struts and fenders. And if offset was any lower, then there should be MORE clearance inside.
The HX wheel is not a dished design, so I can't see caliper clearance being a problem due to spoke curve. But then again, you never know. That's why I'm asking if you saying that the HX wheels won't fit on the front of the Fit is based on experience.
Thanks
Old Apr 11, 2007 | 10:41 AM
rcantu's Avatar
i can't tell you it will or won't fit but it's definitely a light wheel vs. a steelie.
Old Apr 13, 2007 | 03:54 PM
siccmonkey's Avatar
sorry for the delay,i have a set in my garage and wanted to throw them on for fun...nope..back fits fine... the front hits the caliper
Old Apr 13, 2007 | 05:33 PM
j5ive's Avatar
Thank you siccmonkey. That's definitive enough for all.
Glad I didn't just go pick up the set that was for sale before checking here.
Just for future reference, what IS the offset on the HX wheels? I'm guessing it is +50 since if it's +45, it should be the same as the stock steelies, and therefore, no clearance issues.
Old Apr 13, 2007 | 08:10 PM
siccmonkey's Avatar
ok just got home from work and went to the garage to check:
14x5.5 +45, stamped on the inside by the enkei logo
rav
Jan 2, 2013 05:47 PM
drock305
Jan 6, 2010 08:29 AM
treadLightly
Sep 13, 2007 08:37 PM
J.P.
Feb 21, 2007 01:48 AM
Bounty Hunter
Nov 21, 2006 11:57 PM
