Fit I.C.E. Threads discussing in-car electronics including audio, video, security, and navigation systems for the Honda Fit/Jazz
Amp and Subwoofer Writeup 06 honda fit!!!
Old Apr 16, 2007 | 01:28 PM
  #41
BlackFit07's Avatar
For those who want pics of the harness and a readout on the harness so you can tap in the converter, send me an email redstormgsr@hotmail.com
Old Apr 16, 2007 | 07:50 PM
  #42
CuTeBoi's Avatar
Why not just post the picture, label the colors, and that would be all? why the email bit?
Old Apr 16, 2007 | 09:30 PM
  #43
BlackFit07's Avatar
I am not good at posting pictures so if you want to host them email me i'll send you the pics and you do it!!!!!
Old Apr 17, 2007 | 01:21 AM
  #44
CuTeBoi's Avatar
Well, i am right now loading all the pictures, sorting them, and will post what i did with my install.
EDIT: i think i will crash early tonight, and post everything tomorrow, exhausted, cause i think my amp is dead, or something isn't grounded properly, *sobs*
Old Apr 17, 2007 | 05:46 AM
  #45
CuTeBoi's Avatar
https://www.fitfreak.net/forums/fit-...-fit-usdm.html
Ok, i did it =D
And you really should read the forum stickies, especially the announcement that says "how to post pictures" it isn't that hard, and from something someone told me, you must be ghetto, cause you can't read the announcements. (and the fact you are a yankee)
Old May 8, 2007 | 02:24 AM
  #46
taffit07's Avatar
is it easy to take out the side floor panels?
Old May 8, 2007 | 04:26 AM
  #47
CuTeBoi's Avatar
Very.. they snapped out on me by accident when tucking the power cable under them.
Old May 8, 2007 | 01:15 PM
  #48
having a fit's Avatar
i found what the problem was on my amp and sub the remote wire on the amp is ran to my radio fuse so my amp has power all the time since i have the stock radio and a high low converter i dont have a remote wire on the radio so i put in a cut off switch that goes from the remote wire to the fuse and i can turn the amp on and off 50-100 dollar job for 3 dollars all you need is a simple kill switch and electrical tape or connectors
Old May 8, 2007 | 07:49 PM
  #49
CuTeBoi's Avatar
my uncle has a kill switch, but it's also the gain knob, you push it in to turn on or off the amp, and turn the knob to control the sub woofer gain.
Old May 13, 2007 | 11:08 PM
  #50
i dont need the gain knob i cant hear out of my right ear that much anymore too much sound is not good i drive now with the interiors and when im at a show i turn the system on
Old Jul 21, 2007 | 04:32 PM
  #51
tdubl's Avatar
is the stinger saloc converter any good?? it is only 35x2 is that good or bad or should i go for a 50x2 instead?
Old Oct 1, 2007 | 10:46 AM
  #52
tgreaves's Avatar
I got some hunk of crap off of ebay but it has a +12v output when there is signal from the head unit.. Since our stock headunits dont have a remote and/or power antenna wire I needed this to turn my amps on and off..
Im finishing up installing my system tonight so ill see how it sounds.. If it sounds like ass then im going to get a "better quality" low-level converter and then just run the remote amp wires off of the ignition with a delayed relay on them to prevent feedback and popons.. Since I leave my radio on whenever im in the car there wont be any feedback noise, if u dont want to hear the radio then just turn the volume to 0 but still leave the headunit on..
hehe.. Or ill just use the ebay junk converter to output +12v for remote and let a better converter actually convert the sound for me..
Old Jan 13, 2008 | 11:52 PM
  #53
saiko's Avatar
Avid FitFreak Poster
I was hoping for pics? lol
Old Nov 13, 2008 | 12:25 PM
  #54
sevenaprils's Avatar
Okay so I've searched the amp/sub write ups but I can't for the life of me find info where to splice a high low converter without having to remove the factory radio.
From what I've read/heard, there's little difference for the everyday listener between using the rear speaker harness or the harness behind the radio.
I just want to install my sub and amp the easy way, if that's possible.
So any links with good images/directions on the best alternate spot to splice besides the radio harness please and thank you!
Old Dec 21, 2009 | 04:16 AM
  #55
lovelyprasanna's Avatar
please post pics
Old Mar 5, 2010 | 04:17 PM
  #56
drock305's Avatar
I can't fnd anything to ground my amP to.. Can someone help me f
Old Mar 5, 2010 | 09:23 PM
  #57
CuTeBoi's Avatar
Depends on the location of the amp... I have mine where the spare tire goes, I just used the metal tab where the jack goes into, and tapped into that metal piece for my ground.
Old Mar 6, 2010 | 10:34 AM
  #58
drock305's Avatar
Thanks, I looked for a couple hours yesterday and couldn't figure it out.. I'll try that out.
Old Mar 28, 2010 | 11:57 AM
  #59
crash001's Avatar
Normaly I put subs in myself the fit was such a pita I took it to an audio shop and he did it right for 65$ lol I couldent beat that
Old Aug 2, 2010 | 01:18 AM
  #60
kimdizzle's Avatar
why are subs so difficult in the fit?
Hey Y'all,
I've been reading through some threads on here and have noticed many people think installing subs is kind of a pain in the a-- with the Fit...Just wondering what exactly is tough about it. I am pretty inexperienced with car audio stuff, but my cousin seems to be pretty knowledgeable and he volunteered to help me out. I am planning on putting in a new headunit and some JL Audio subs.
Thanks.
