How to un-install front oem lip ?
Old May 10, 2007 | 08:47 PM
iheartmyGD3's Avatar
So i'm having trouble figuring out how to pop out the front oem lip. So far I have found 2 screws on each side of the fender ... I saw some brackets in the middle part of the front lip but I cant figure out how to unscrew them... Help please
Old May 10, 2007 | 11:52 PM
elee's Avatar
Yeah.... I'd like to know too!!
Old May 11, 2007 | 12:15 AM
BUMP.
Anyone???
Old May 11, 2007 | 12:39 AM
ezekielwhore's Avatar
hit up chris (JDMchris)
Old May 11, 2007 | 12:56 AM
JDMchris.com's Avatar
I run THIS
Howd I know my name would be mentioned. Anyways the easiest way is to remove the front bumper which is only a extra 5 minute step. After removing the bumper there are i believe 5 bolts that need to be removed (besides the 2 screws on the inner bumper)
thats it.
Old May 11, 2007 | 02:19 AM
thats it.
Thanks bro. I ended up just cutting the plastic mounted onto the brackets .. I finally got the CF lip on!
Old May 11, 2007 | 01:08 PM
elee's Avatar
thats it.
Is there anyway of doing it without removing the whole bumper...I'm not much of a handy man....The less I remove the less I screw things up lol...thanks
Old May 11, 2007 | 01:14 PM
I run THIS
yes, but is more of a PITA to do it that way. the only extra thing you would need to do to remove the bumper is the 2 screws that hold the bumper and 4 pop clips.
Old May 11, 2007 | 01:41 PM
elee's Avatar
Oh ok...i just took a look at the the bumper....so the 2 screws that hold the bumper is located at the bottom or the wheel well?
Old May 11, 2007 | 02:21 PM
I run THIS
Yes those are them.
so in total what you have is:
the 2 screws on the bumper
8 pop clips underneath the bumper
and 4 pop clips on top.
Pop clips are easy to remove, basically all you need is a flathead screwdriver.
jasonh
Sep 14, 2011 11:02 PM
Fitguy07
May 17, 2011 12:52 PM
xonexlifex
Mar 25, 2010 06:33 PM
chinkyy
Dec 8, 2009 01:47 PM
dmagic17
Aug 22, 2009 04:14 PM
