Radiator flush?
Old May 14, 2007 | 03:28 PM
thedeadpoet000's Avatar
Radiator flush?
has there been a DIY posted to do a radiator flush on the Fit?
I know where the drain bolt is for the radiator but my main question was how to empty the coolant from the reservoir.
Do I just remove it(the whole reservoir) and pour out the contents or is there an easier way?
Also, to empty out the coolant from the radiator, do I just take off the drain bolt, let it all out, bolt back, and pour in new coolant?
Is there anything else I need to do?
Old May 14, 2007 | 10:50 PM
Fit of RAGE's Avatar
yeah, all you do is open the rad cap, undo the rad drain plug. take the rez. completely out and dump it. Then put the rad drain plug back in and start filling the coolant up. Easy!
Old May 15, 2007 | 02:03 AM
SSM0423's Avatar
Are you flushing out JUST the radiator or the coolant that's also in the engine too? They sell over-the-counter flush kits that you hook up to a garden hose to flush out ALL the coolant, not just the radiator. Food for thought. Just make sure, you get all the air out of the cooling system before putting the cap back on or you'll overheat.
Old May 15, 2007 | 02:59 AM
how much do those flush kits cost, and are they complicated? I thought all the coolant in the engine would eventually flow into the radiator once i unbolted the plug, but i guess not.
could i do a couple of flushes for the radiator to get all the coolant swapped?
Old May 15, 2007 | 08:53 PM
lol P yes yes i am newbish. thx for the advice though.
Old May 15, 2007 | 09:12 PM
Carbuff2's Avatar
Originally Posted by claymore
Those "coolant kits" for flushing don't work all that well. Think about it the minute normal temperature water hits the thermostat it CLOSES so no water circulation.
Actually the intended spot to install those Flushing Tees is on a heater coolant hose, just behind the thermostat.
This way you flush through the heater and radiator cores. Yes the thermostat will be closed but the fresh water will enter the cooling system just after the thermostat, and exiting at the radiator cap, a few inches from the other side of the thermostat..
I used to put them on every car I owned, but no longer. Why? Because I use distilled water in my cooling systems now, not tap water.
PS the blue Honda coolant is supposed to last 120K miles. And you should not mix the Honda coolant with any other brand. (Per Honda)
Old May 15, 2007 | 10:10 PM
manxman's Avatar
I agree with Carbuff2-
He accurately describes how and why the flushing tees work. I have also used the flush system on at least 10 cars/trucks, but will not use one on my Fit for the same reason as Buff.
Old May 15, 2007 | 11:31 PM
sonorliteman's Avatar
(Per Honda)
An excellent point...this is a key to keeping your cooling system & engine block free from deposits & buildup. Or use pre-dilluted stuff.
On my old 95 Civic, previous owners did not use distilled, & the radiator had build up a coating of white calcium deposits that no amount of flush could remove...couldn't imagine what the block core looked like.
Old May 16, 2007 | 09:39 PM
thx. the reason i want to do this flush is b/c all my coolant leaked out when i put in my old Fujita CAI and i had to replace it with prestone. now i wanted to go buy some honda coolant and replace it back. i wanted to do this so that if something happened to the radiator, they can't blame the different coolant and wiggle out of the warranty.
does anyone know how much the coolant costs at a honda dealership?
Old Feb 27, 2013 | 11:02 AM
dewthedew's Avatar
bumping an old thread but whatever, how do you bleed the coolant system?
Old Feb 27, 2013 | 08:14 PM
Carbuff2's Avatar
Honda shop manual says, "Fill radiator but leave cap loose, run until fans turn on twice, then top off radiator and reservoir"
But it ain't that easy.
I say, top off rad, squeeze upper rubber hoses to drive out air in them. Run engine 5 - 10 minutes, then shut off. After a half-hour, top off radiator and reservoir. Repeat.
Use Honda coolant.
Then, check the reservoir daily, for a week. Add coolant to reservoir as needed...the level will drop, then stabilize...
PS: during that first week, run the warmed-up engine near redline a few times, this also purges air pockets due to the velocity of the coolant.
Mister Coffee
Mar 14, 2024 03:23 PM
domromer
May 22, 2019 03:15 PM
doctor J
Jan 23, 2019 03:02 PM
Kasek
Jul 10, 2018 06:15 PM
Bugzs15
Nov 5, 2013 06:57 PM
