Radiator coolant level.
Old Nov 4, 2013 | 06:12 AM
Bugzs15's Avatar
I was wondering what other people have noticed when they open their radiator cap. My coolant does not seem to sit at the neck of the radiator opening but is further down inside the short coolant hose coming from the radiator top tank. Is this normal for the 1.5l fits?
Old Nov 5, 2013 | 02:01 AM
loudbang's Avatar
If it is only down far enough that you can still see it then that is normal. If you can't see it then it's time to add some coolant. But anyway you should be checking the level at the coolant overflow tank not opening the radiator cap all the time.
Old Nov 5, 2013 | 02:04 AM
Bugzs15's Avatar
Yep can definitely still see it. Just confused as thought its meant to be at the very top of the radiator neck.
Old Nov 5, 2013 | 10:13 AM
smartin108's Avatar
Do you hear a sloshing/swishing noise when you turn the temp knob to heat? If so you have air in the system.
Old Nov 5, 2013 | 05:47 PM
Bugzs15's Avatar
No sloshing at all. I was listening for it as well as I suspected air in the system. Just wanted to check what other fit owners see when they take off the radiator cap.
Old Nov 5, 2013 | 06:57 PM
Carbuff2's Avatar
Finding the level up to 2" (50MM) below the cap (with a cold system) is not a cause for concern with modern coolant recovery systems.
As Loudbang said, if you cannot see the coolant in the rad, THEN add some...and do a system pressure test.
doctor J
Jan 23, 2019 03:02 PM
willfit07
Nov 21, 2016 05:25 AM
cakacon
Oct 15, 2011 08:35 PM
john21031
Oct 19, 2009 10:45 PM
Fijoy George
Aug 10, 2005 12:20 PM
